Springs? Shocks? Suspension?
dopie
Premium Member
Premium
ionno what it is but
when i turn onto my drive way or go over a speed bump
i here a clunk from my driver side wheel area
its a loud one also cuase i can hear it and the passenger side does hear it also
so ionno if any of you have had this problem before
it happend after i got my eibachs installed
so any info??
how fast r u going over the bumps? sometimes if im not careful at school and going a lil too fast over bumps it makes a big clunking noise also
so any info??
Check your suspensions nuts and bolts they could be loose.
my passenger rear has a chain-like noise whenever i go over little road bumps, but not big bumps. Like ic an go over a speed bump fine, but if it's like little bumps in the road you can hear it. dealer said there wasn't a problem... :-/
Your parking brake needs adjustment.
i believe that clunk you are hearing from the drivers side is from the fender nuts loose, theres a recall somewhere describing the exact symptoms you are having , i have the asme thing just havent brought it in yet
2003-2004 ///4997&highlight=fender+bolt ... not sure if it applies to 05+ but worth a try..check your dealer.
It could also be your springs, since you said it happened only after the install. Visually inspect your suspension and recheck the torque specs
