Speedo Calibration
Discussion in 'FX (03-08) - Wheels & Suspension' started by RideOrDie, Jul 22, 2007.
  1. RideOrDie
    RideOrDie Member
    106
    Los Angeles
    Now that I've gotten the wheels, would I need a speedo calibration done? I'm running a 285/35/22 profile.
  2. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    What is the width of your new wheels?
  3. OP
    RideOrDie
    RideOrDie Member
    106
    Los Angeles
    width is 9.5
  4. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    From your stock tires to these current ones there isn't a huge difference. Its about 1.9% faster. So if you were going about 60mph the speedo would read about 58.9 mph. This is based on if you were coming off of the 20in oem wheels. On the other hand, if you were coming from the 18in oem wheels then there would be a 2.2% difference equating to about 58.7 mph actual speed on the speedo reading 60mph.
  5. rookie
    rookie Premium Member Premium
    2,201
    29
    Westminster OC
    Car:
    car
    The overall height of the oem size vs the 285/35-22 size is about 1/2". As Dr.2K said it results in a 1.9% difference. It shouldn't be too far off that it would require a speedo recalibration.
    I'm not totally positive but this difference may also affect the odometer and the mpg display as well. All minimal differences.
