Rear Hatch Chrome Trim Removal
Discussion in 'FX (03-08) - Interior & Exterior' started by gchristopher9, Mar 20, 2008.
  1. Does anyone know if the chrome trim pieces on the rear hatch are removable? Mainly the pieces above and below the license plate? I'd like to tackle painting these black on my own, but don't feel comfortable doing it on the car. Any idea?
  2. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    I think FXLR8 should be able to help you out with that question. He painted his along time ago.
  3. turbocad6
    turbocad6 iS VIP iS VIP
    8,341
    59
    brooklyn, ny
    you gotta pop the rear door panel cover off & theres a few 8mm or 10mm nuts to remove... even after the nuts are off though there still held on with clips. there a bitch to get off without damaging anything...
  4. fxlr8
    fxlr8 Staff Administrator
    17,958
    769
    California
    None
    I actually slightly cracked my top trim piece trying to take it off, but after I painted it you couldn't even see the crack.
    here is the diagram.
  5. OP
    gchristopher9
    gchristopher9 Member
    any suggestions on what i can do to get it off in one piece? what if i back the screws off from inside, and then push in on them to pop the piece out? would that work?
  6. turbocad6
    8,341
    59
    brooklyn, ny
    just pushing the studs won't do it, the clips are very tight. once you get the first one though then you got more leverage & better grasp to pull the rest. hard to explain, just gotta play with it... the lower was tougher than the upper from what I remember, I think I made a tiny mark in mine when I took it off, there expensive little buggers too, those trims...
  7. OP
    gchristopher9
    since i plan on painting them gloss black i think i can deal with some minor nicks and scuffs. i just looked n everythinginfiniti and the set goes for about $250
  8. fxlr8
    17,958
    769
    California
    None
    Here is a pic of a spare I have.
    These things are expensive, but I found this one on ebay.
    The red clips are a pain in the behind.
  9. gto
    gto Track Ready Moderator
    16,512
    539
    Los Angeles, CA
    05 FX35 RWD
    Wow, I always wondered what the whole enchilada would cost if you parted the whole thing. Turbo? guesstimate?
  10. turbocad6
    8,341
    59
    brooklyn, ny
    I know if you had to buy all the parts seperatley retail to build a car it comes to several times what a whole car would cost... I read somewhere once but don't remember exact #'s but it was something rediculous, like 150k for a 30k car or something...
    I seen that molding or one like it on ebay, but the ones with the tech button are hard to find...
  11. OP
    gchristopher9
    can you take a close up shot of those red clips? are they not accessible from behind, like the screws are?
  12. turbocad6
    8,341
    59
    brooklyn, ny
    don't think so but don't remember for sure, that picture is a good help though as far as location & stuff, again, the lower was much harder than the top one... mainly cause there is nothing to grab & pull...
  13. fxlr8
    17,958
    769
    California
    None
  14. gto
    16,512
    539
    Los Angeles, CA
    05 FX35 RWD
    So basically, ya add it all up & you end up with a Rookie :LOL: . . . Oh, but then ya gotta assemble it.
  15. gto
    16,512
    539
    Los Angeles, CA
    05 FX35 RWD
    What else could you do with that red thing, hmmm. Maybe a BtPlg
  16. Psiclne
    Psiclne Guest
    I thought it and you said it - :LOL::LOL::LOL:
  17. OP
    gchristopher9
  18. gto
    16,512
    539
    Los Angeles, CA
    05 FX35 RWD
    Painted Black?
    Any more pics?
  19. OP
    gchristopher9
    yup. sanded the Infiniti letters off the top piece, then painted gloss black. i'll put up some shots with a real camera a little later on. took a couple failed attempts at a good finish using the acrylic enamel so i started over and used acrylic laquer and had much better luck. wet sanded with 2000 grit and polished with compound.
  20. gto
    16,512
    539
    Los Angeles, CA
    05 FX35 RWD
    . . sounds good
    I kinda like the lettering detail on the FX rear, but I can see this working too.
