rear bumper plastic trim
Discussion in 'FX (03-08) - Interior & Exterior' started by Guest, Jun 5, 2007.
  1. Guest
    Guest Guest
    heres a picture...dont ask what happend [​IMG] need to know if i can buy just the plastic trim or will the whole bumper need to be replaced
  2. OP
    Guest
    Guest Guest
    eewwwww...that looks bad. I would think the top bumper could be redone by a body shop but the lower plastic piece is the problem. If those two pieces are not seperateable then I would think you would need a whole new bumper.
  3. OP
    Guest
    Guest Guest
    That does look bad... if you don't replace the bumper look at having it all painted to match. There are a few FX's that have the trim painted. Just another option, the cost may vary. but something else to think about
  4. OP
    Guest
    Guest Guest
    The pieces do not separate, new bumpers come in the lower finish and the upper portion just gets prepped for paint. Upper is repairable as is the lower but the finish wouldn't be exact to the rest of the black trim.
  5. OP
    Guest
    Guest Guest
    Re: rear bumper plastic trim (Krayzie)
    oh man that does look bad....the painted part of the bumper i assume would not be that difficult to fix, but its the bottom plastic part i think is the problem.
    i dont think there is a fix for it, unless maybe they put some filler and paint the whole bottom part of the bumper for you...then you might as well paint the bottoms all around View attachment 117058
  6. OP
    Guest
    Guest Guest
    Re: rear bumper plastic trim (brown_fv)
    Did you get it fixed?
  7. OP
    Guest
    Guest Guest
    Re: rear bumper plastic trim (rookie)
    i just checked the thread now, didnt think there were any posts...the light bulb didnt turn on View attachment 117061 haha. it hasnt been fixed yet, but i got some Mothers back to black and about 2 feet from the bumper it is hardly noticable...temporary fix for now i guess View attachment 117064
  8. OP
    Guest
    Guest Guest
    It almost looks like it could be wet sanded with 600+ to get some of it out. A body shop's recommendation could be useful if you're getting the paint part fixed.
  9. OP
    Guest
    Guest Guest
    Re: (rookie)
    rookie...you talking about the plastic or paint part? the scratches went right through the paint.
  10. OP
    Guest
    Guest Guest
    Talking about wet sanding the plastic so it is smoother, the gouge in the paint should be repairable and repaintable. Just thinking of what it would take to get it close to the way it was without replacing the bumper.
  11. OP
    Guest
    Guest Guest
    Re: (rookie)
    good idea rookie, ill look into it
  12. FXshift35
    FXshift35 Member
    130
    New Jersey
    i saw one with chrome before and a shinier glossier appearance, where can i order these?
  13. 2010fx35
    2010fx35 Member
    642
    Oregon
    Car:
    2010 Fx35
    mine got dented in.....is there any good way to fix it? Heat gun, molding? somthing?
  14. ocal21
    ocal21 iS VIP iS VIP
    7,898
    297
    Boston, MA
    Car:
    2012 FX35
    Name:
    Oscar
    Wonder if this ever ot fixed
  15. Brooklyn
    Brooklyn Member
    155
    brooklyn, NY
    bump
