- Edmonton,AB
Does anyone know the specs/sizes for our OEM speakers/amps?
Bad idea IMO. The stock speakers have paper woofers and will probably tear easily if you take them to or just over their design capacity.
A small (8") subwoofer will fit in place of the stock bose one in the spare wheel well with a fiberglass enclosure and will deliver much more than the tiny woofers in that plastic Bose case:
ordered my stuff today! going to put my amp inside my spare tire well, and build a nice wedge box to point towards the rear hatch. CAN'T WAIT!
I used Infinity Reference 3002/3012, the 3052 (I believe) don't fit and I gotta swap out the 3052's for my ol' 3012's again because the 3052's are too deep.your best replacement may be your infinity kappa, or your boston for your mids/highs based on speaker mounting depth, your dash and pillar locations are swallow
Hopefully I'm answering your question correctly you have a total of 10 speaker locations in the FX; front dash 1L, 1C, 1R each position will accept a 3" or 3.5 replacement. 4 door speakers will accept 6.5 replacement speaker, rear pillars will also accept a 3 or 3.5" replacement speaker, and last your sub. like cube said the bose sub enclosure has dual 5.75" paper cones contained with in. your best replacement may be your infinity kappa, or your boston for your mids/highs based on speaker mounting depth, your dash and pillar locations are swallow, and depending on your speaker choice you'll have to modify the mounting location just a bit... I hope this was what you were asking...
Btw, you meant shallow, right?![]()
That does help. Thanks. I'm not too concerned with the dash speakers but would like to upgrade the doors and rears eventually. In regards to the sub, I think I'm gona take your advise Cube and wait to do it right. Except right now I wont be doing anything cause it's -34 degrees outside!
This answered many questions i had too, thanks Dee!Hopefully I'm answering your question correctly you have a total of 10 speaker locations in the FX; front dash 1L, 1C, 1R each position will accept a 3" or 3.5 replacement. 4 door speakers will accept 6.5 replacement speaker, rear pillars will also accept a 3 or 3.5" replacement speaker, and last your sub. like cube said the bose sub enclosure has dual 5.75" paper cones contained with in. your best replacement may be your infinity kappa, or your boston for your mids/highs based on speaker mounting depth, your dash and pillar locations are shallow, and depending on your speaker choice you'll have to modify the mounting location just a bit... I hope this was what you were asking...
i think come spring/summertime i will be working on my sound system. since i go on a lot of road trips and the FX is used a lot, i think i will incorporate the space where the spare tire is to put my enclosure so it doesnt use the trunk space. i will be taking out my spare tire equipment so i wont be putting on any extra weight by changing my system, it will basically cancel each other out.
LMAO i was just reading my own post and realize i should do the complete opposite. i will be driving without my spare and tools (roadside assistance) although i SHOULD put them back in when i go on trips so i guess the most logical thing for me to do is have my sub/amp setup in the trunk probably on one of the side (or maybe both if i have dual subsThis answered many questions i had too, thanks Dee!
LMAO i was just reading my own post and realize i should do the complete opposite. i will be driving without my spare and tools (roadside assistance) although i SHOULD put them back in when i go on trips so i guess the most logical thing for me to do is have my sub/amp setup in the trunk probably on one of the side (or maybe both if i have dual subs)
