QX70 09+ OEM Instructions for Aero Rear Under Protector
Discussion in 'QX70 Write-Ups' started by GEE50FX, Apr 3, 2015.
  1. GEE50FX
    GEE50FX The Traveller iS VIP
    18,281
    821
    Kincardine, Ontario, Ca
    2010 White FX50S-sold
    Wayne
    I have not installed this part yet but below are the OEM instructions for this part.
    Here it is installed
    rex9271 and SIDE FX like this.
  2. SIDE FX
    SIDE FX Premium Member Premium
    153
    19
    Philly AKA Philadelphia
    2009 Infiniti Fx35 AWD Twilight
    Brian
    Looks real good nice job.
    GEE50FX likes this.
  3. FQ50s
    FQ50s Member
    19
    16
    Silicon Valley
    Fx50s
    Shaun
    Ok..i did this myself over the weekend. Key is to have all the right tools, particularly the drill bits!
    Start off by using template for the rear hole (yes, you have to make a 16mm hole in the rear bumper). Use a hole punch to align properly and then drill accordingly.
  4. FQ50s
    FQ50s Member
    19
    16
    Silicon Valley
    Fx50s
    Shaun
    Next you’ll want to jack up your car and take off the wheels as you need access to the wheelwells. Then, use the supplied template to make 2 1/4” holes. Note: you dont need to pull the wheel well moldings, just becareful where you drill. Afterwards, place in the nut clups and pull out 1 bolt underneath by the wheel well and 1 push clip under the back bumper. Now pull back some of the 3m adhesive on each side and place the rear body panel on bu aligning the hole in the bumper first and then pushing it into wheel well. Now screw in the tapping screws to the nut clips at wheel well and the larger screw supplied underneath. The trickiest part is getting the white plastic block onto the body kit. You do this by accessing the inside of the bumper theough the bottom rear and aliding it in until it clicks. Takes about an hour tops to do it, if yiu have the right tools and as always measure and align evrything properly first!
    GEE50FX likes this.
  5. OP
    GEE50FX
    18,281
    821
    Wayne
    Good report, well done.
