FXtion
- sherman oaks, ca
has anyone used nitous on their FX stock engine. What are the results???
When I was at Shawn Chruches shop on the Dyno Day, the guy from Nissan Magazine suggested that I get a Intercooler (IC) cooler. The company DEI make a system called CRYO2 which consists of a Tank filled with CO2 Gas which is piped into a Ring that is installed on the IC. Using a Switch, it sprays CO2 Gas on the Intercooler which dramatically reduced (almost freezes) the air going though the IC which will drop the AIR tempreture going though the IC. They also have another Option that has a Ball inside a 3" Intake Tube which CO2 passes though which subsiquently reduces the air that is going though the Intake tube.
The problem with CO2 (Carbon Dioxide) is that it replaces oxigen (deoxidizer) which is needed for Combustion. If CO2 comes in contact with the AIR that is entering the engine, it reduced the Horsepower since it's reducing the amount of Oxigen.
On the Other hand, N2O (Nitrous Oxcide) has the exact oposite effect. N2O is a non-combustable Oxidizer which elevates the amount of Oxigen as well as having the same Temp reducing caracteristics. Nitrous is used in Combustion Engines to produce high levels of HP due to these caracteristics. Usual application of N2O in race engines is direct injection of the gas into the intake or directly into the cylinder head.
If not used properly, N2O can kill an engine due to generating extream heat levels that is caused by bigger explosions inside the cylinder chainber.
Now My Questions: The Same CRYO2 system can be run with nitrous instead of CO2. This means that IC can not only be cooled while engine is idling, it can also be used in higher RPMs without the Oxigen robbing efects of the CO2. The Problem is that how much of the N2O will get into the intake and what sort of problems will it cause for the engine.
I would imagine the resedues of either gas getting into the intake is not that much to cause a concern, however, I do not want to take any unwanted risks.
CO2 is effective enough to cool down the IC before runs, but N2O is effective before and during. Since the Port hole for the Intake is very close to the front of the FX Engine, I'm concerned it might put too much of one or the other into the intake.
Anyone has a different oppinion or experiance?
