FX45 Nismo Exhaust - 2005 FX45
Discussion in 'FX (03-08) - Engine & Drivetrain' started by Dr.2K, Dec 17, 2007.
  1. Dr.2K
    Santa Clarita, CA
    2005 FX45
    Originally posted on Sept. 22, 2005 - .Org
    It was a bit of work getting the system to fit on the 45. The overall compatibility I'd say was 90%, with 10% custom work needed (cuts, bends, and welding here and there). I have to say tho that as of right now the nismo exhaust on the fx45 does NOT sound the same as on the fx35. I thought the overall tone of the exhaust would be the same but only deeper than on the 35 but it is not. However, it is definitely throatier. My first impressions are as follows:
    1. Less but deeper rumble at ignition
    2. Tone is a bit higher in pitch but has deepened with time
    3. Overall sound is different and very noticeable and aggressive on load
    4. No immediate or long term torque loss noted
    Also, I have not yet added UTR y-pipe so that may also change things. I wanted to add one variable at a time to see and feel the changes.
    Note: With the addition of the 3in UTR Y-Pipe and the G35 extension piece the exhaust system seems to sag at the connection point of the two. So there was a need to add a extra hanger in that area for added support.
    Compliments the nismo exhaust very well and gives a much throatier note and seems to free up the exhaust a lot more. Highly recommended!
    Sound clips here: Nismo Exhaust on FX45 Idle & Load - InfinitiScene.com
    Same day install of Nismo exhaust with stock Y-Pipe.
    Nismo with Stock Y-pipe video by pscdoc - Photobucket@@AMEPARAM@@http://vid9.photobucket.com/player.swf?file=http://vid9.photobucket.com/albums/a89/pscdoc/MOV00490.flv@@AMEPARAM@@vid9@@AMEPARAM@@9@@AMEPARAM@@a89/pscdoc/MOV00490
    1 Week after install of UTR Y-Pipe with nismo.
    MOV00508.flv video by pscdoc - Photobucket@@AMEPARAM@@http://vid9.photobucket.com/player.swf?file=http://vid9.photobucket.com/albums/a89/pscdoc/MOV00508.flv@@AMEPARAM@@vid9@@AMEPARAM@@9@@AMEPARAM@@a89/pscdoc/MOV00508
    Almost 2 years later. With UTR Y-Pipe
    Nismo FX45 video by pscdoc - Photobucket@@AMEPARAM@@http://vid9.photobucket.com/player.swf?file=http://vid9.photobucket.com/albums/a89/pscdoc/d2143c16.flv@@AMEPARAM@@vid9@@AMEPARAM@@9@@AMEPARAM@@a89/pscdoc/d2143c16
  2. Other than the differences in sound, is there any difference in performance that would be noticed when you step on the gas, or is this a mod that just makes it different from stock?
  3. jbaker1121
    Westchester, New York
    09 FX50
    it wont add that much powerr, but it will sound liek it did. thats why im keepign the stock exhaust :)
  4. OP
    Santa Clarita, CA
    2005 FX45
    You will gain some top end power due to the larger 3in Y-pipe and exhaust. Plus I think it sounds much better then the oem exhaust note.
  5. Chedman13
    Chedman13 iS VIP iS VIP
    1) It's Nismo!
    2) You're tuned w/ Technosquare
    3) It was made for a 3.5L V6
    I could be wrong but I have a feeling you didn't lose anything! If the company made this and it was for a smaller displacement of 3.5L V6, I think you would only gain from adding it to a 4.5L V8, especially since you got it tuned.
    Either way, whatever gain/loss, the sound is awesome and who else has a Nismo exhaust on a FX45 (or maybe you are the only one?)!
  6. Psiclne
    Psiclne Guest
    Trainerken has it on his 45
  7. gmgagne
    gmgagne Member
    Potomac Falls, VA
    09 FX50S 06 FX45
    hey where can you get that done and how much would labor be?:biggrin: thinking on doing it for my fx45 not the 35
  8. question on exhaust
    Not 2 be reachin, but about how much would a catback nismo exhaust set me back!
  9. bleedingsujit
    bleedingsujit Premium Member Premium
    that actually sounds very good. like it's under tremendous pressure. i would have to del my cats to get it as loud as it is.
  10. OP
    Santa Clarita, CA
    2005 FX45
    Brand new right now about $1,200 on ebay. But from a online retailer around $,1,500. The best way is to look around for a used system on the 350z forums.
  11. fxBeast
    fxBeast Member
    San Diego
    2006 FX35
  12. Wow! Nice photos and videos of your Nismo Exhaust - 2005 FX45. I think I should try to purchase that kind of exhaust. :)
  13. Thanks for the writeup & tips, I appreciate it.
