Need Help On What 22" Tire Size To Get!! Wheels Are Coming In Monday
Discussion in 'FX (03-08) - Wheels & Suspension' started by Kkrogers, Oct 19, 2007.
  1. Kkrogers
    Kkrogers Member
    55
    Cottage Grove, OR
    :confused:I am trying to figure out what size of tire to put on my new wheels. I have Zinik Z6 22 x 9.5 wheels with 35mm offset coming in on Monday and I still cannot figure out what size of tire to put on them. I don't want to go too narrow or too wide and I am kind of stuck with Toyo Proxes sizes. The size that my dealer is suggesting is 265/40/R22, but it is almost equal to the stock size tire according to their specs. I would like to go a little wider if possible.
    Any suggestions? What about the 285/35R22? That is a little wider and a little lower profile.
    Please help!~ I need to order tires soon, I can't wait to get them on the car!
    Thanks,
    K
  2. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    I think the best bet for tires if you want to go with 285's are these;
    http://www.tirerack.com/tires/Compa...ting=Y&speed_rating=(Y)&RunFlat=All&x=70&y=13
    There will be a slight decrease from the oem height but not really noticeable and you speedo with be off 1.9% too fast. No big deal. Or you can go bigger to the 305/35/22 like on mine. And the only choice for 295's that would be close to oem height is this;
    http://www.tirerack.com/tires/Compa...W&speed_rating=Y&speed_rating=(Y)&RunFlat=All
  3. brown_fv
    1,703
    Toronto, On
    i think 285/35-20 would be good but the tires are a bit small. what about 285/40-20?
