Need Help Changer issues!!!!
Discussion in 'FX (03-08) - Interior & Exterior' started by spdjunky, Dec 16, 2007.
  1. spdjunky
    spdjunky Member
    Just bought an 03 FX 45, the indash changer had six CD's in it from the previous owner I ejected the first and it came out fine. Then it decided it didn't want to let the rest out, or even play them for that matter. Radio works fine......just no CD functions....is there a separate fuse, or some kind of relay reset specifically for the CD changer? Does anyone have any info that will help me out????? I know, who uses CD's I will have an IPOD kit installed, but I would to have everything in working order. Thanks
  2. fxlr8
    fxlr8 Staff Administrator
    17,961
    770
    California
    None
    Probably broken since the previous owner left cd's in it. Try disconnecting the battery for 30 seconds or more and reconnecting, this usually resets the cd player and you should hear it cycling the cd's. If that doesn't work you probably have a defective unit and need to replace it.
  3. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    Exactly my same thoughts. If the battery trick doesn't work then take it to the dealer and have them do it or replace it. Is the FX still under warranty?
  4. Psiclne
    Psiclne Guest
    Probably not since its an 03 - unless they got the extended.......i remember some Org guys having issues and the dealer had to replace it.
