Need advice for brake pads
Discussion in 'FX (03-08) - Wheels & Suspension' started by brown_fv, Aug 8, 2007.
  1. brown_fv
    1,703
    Toronto, On
    hey guys. next week im going to set up an appointment to replace my brake pads and right now i am looking for some options on replacements.
    i do however find it a bit weird that at 24,000KM (15,000 miles) the brakes need replacing...would they cover that under warranty by any chance?
    right now i am looking at the oem pads which on infinitipartsusa.com i can get a whole set (front & rear) for $83.69 before shipping. what about hawk pads? i have read some good things about them and a few bad things, but where can i get them and how much would they cost? are there any other brand of pads is should look into?
    thanks.
  2. Chedman13
    Chedman13 iS VIP iS VIP
    9,168
    103
    Illinois
    Car:
    To answer some of your questions, if you have no issues with the OEM pads, I'd stay with them.
    I had squealing issues, so went with akebono proact and couldn't be more happy. No real difference, just that they are silent and not too much brake dust. You can do ebay or www.tirerack.com You will see a lot of options for our cars when you enter in your model. Hawk HPS I hear are really good as well. Try reading the reviews on tirerack.com, that should lead you to your choice.
    FYI - I'm running OEM rotors.
  3. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Akebono will be my next set of pads to try. Axis has wayyy to much brake dust. Hawks I heard were good but a bit dusty also.
    If you are going to sat with oem rotors then stay with the oem pads or go with akebono since Chedman seems to have good results with them.
  4. Z33_2_FX35
    Z33_2_FX35 Member
    270
    Dallas Texas
    Get a Big Brake Kit like Endless, AP Racing, StopTech, Brembo....etc Use this maintenance as an excuse to do it....DoooOOOOOO IT!!! :wub::rolleyes:
  5. HumbertoCALI
    3,868
    South Gate, CA
    Car:
    2003 FX45 AWD
    DooOOOOO IT!!!!!:biggrin:
    DooOOOOO IT!!!!!
    DooOOOOO IT!!!!!
    DooOOOOO IT!!!!!
    DooOOOOO IT!!!!!
    DooOOOOO IT!!!!!
    DooOOOOO IT!!!!!
    Wish I could.:mad::frown:
  6. Chedman13
    9,168
    103
    Illinois
    Car:
    Dr. 2K,
    Since brake dust seems a factor for you, just wanted to let you know that I've had OEM Pads in Front and Akebono Pads in Rear for a while before I switched to all Akebono.
    The OEM pads and Akebono pads gave off about the same amount of brake dust, which I considered to be very light. Off topic - I bought new rotors which I'll install in about two months when my pad life is up (going akebono all around again). Went with Centric Premium rotors (http://www.centricparts.com/prod02.htm) which I found out are the blanks that Stoptech uses when they slot or cross drill their rotors. $250 shipped to my door for four rotors. I decided that a plain rotor was best for my scenario after numerous hours of online reading on plain vs slotted vs cross drilled vs slotted and cross drilled vs dimpled, etc...
  7. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Good to know Chedman, thank you. The combo I am running now is working out great (no squeeking and VERY low brake dust) until I decide to to the BB kit upgrade.
  8. OP
    brown_fv
    1,703
    Toronto, On
    AHH! im going to quit the scene because of peer pressure :frown:
    next spring/summer when i get some forged rims the oem brakes will look kinda small...then it might be time for a BBK!:LOL:
  9. Z33_2_FX35
    Z33_2_FX35 Member
    270
    Dallas Texas
    Relax man...just charge $6500 for an Endless BBK set on the cc and forget about it. ;) If you were local I'd even help you install them :biggrin:
  10. OP
    brown_fv
    1,703
    Toronto, On
    LMFAO! my personal creditcard limit isnt even $5000 yet! if i use my other card that goes to my dads account on the other hand *no limit*...i might have to go TT at the same time i go BBK!:rofl::rofl:
    on a more serious note though...i was talking to my dad and he said that its way too early to need new brakes but i let him drive the car and he agrees with me they need replacing. he said they should be covered under warranty because im only at 24,000KM...is that right, or should i just try and BS the dealership into replacing them for free (although i bet the dealership will say they are fine)
  11. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Brake pads = normal wear and tear items and will NOT be covered under warranty unless the pads were defective somehow.
  12. OP
    brown_fv
    1,703
    Toronto, On
    hmm...i guess i will get the OEM brake pads then. after the conversion rate + shipping it should come to about $100 for the front+back brake pads. hopefully the install will be no more than $150 right?
  13. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Here in the US I think the going infiniti tech labor rate is $90-95/hr. I think this is a 1-1.5 hr job. It should be around that much.
  14. OP
    brown_fv
    1,703
    Toronto, On
    just a quick update, today i ordered new brake pads online. EBC Green Stuff...ive heard good things about them so i thought i would try them out. will post impressions and thoughts after i get them installed.
  15. Psiclne
    Psiclne Guest
    Doc, What are you running now?
  16. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Oem brake pads with the stop tech stage 2 cross drilled rotors from the org GB awhile back.
  17. Psiclne
    Psiclne Guest
    Did LMS put the rotors on for ya? If so - do you remember how much they charged?
  18. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    I will let you exactly tomorrow Will. I have the invoice at my office. But I believe it was around $200.00. They ordered the oem brake pads for me from metro infiniti.
  19. Psiclne
    Psiclne Guest
    Doc, so you recently put on the Cross Drilled? Was it that day I met up with ya at LMS? I thought you were there to change the pads only.
  20. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Yes, I was there only to replace the pads. But I had LMS install the stop tech stage 2 brake upgrade from the org's group buy last year. I thought you were asking how much it was to do everything, no? It was around $200 to install the stop tech upgrade. But you are right that dau when I saw you I was only there for the brake pads.
