Maguiar's Quick Detailing Spray
Status
Not open for further replies.
^^i wouldnt...you should do a quick wash. there will be some particles still left on the paint and when you spray this and move around the cloth you will cause scratching. this is an alternative to actually waxing.
just give it a quick wash and use this the whole process will take under and hr.
I use a quick detailer as well, the only scratches I have are from some idiot the use a nasty az towel to wipe my car down when I picked it up at the port. still pissed every time I see them. BUt the Detailers are pretty good as long as there isn't heavy build up.
I had to order some Zaino though just to see what the big to do is all about. I ordered the AIO, and the Z5 so we'll see next week.
Can you polish them out with some 3M Rubbing Compound or similar?
I used some scratch X, and it hides them pretty good but they are still there. Blk shows everything. once I can find a professional detailer then they'll be gone. but I'm claying the car shortly, well the hood for the most part and see if I can work them out.
Naw surface scratches, you really can't see or notice then unless in a dimly lit area, looking at an Angle, no swirl marks just marks from someone wiping the car down with a hard dirty towel.
You also try their Detailing Spray. Zaino calls it their Gloss Enhancer Z6.
I am a Zaino junkie and have been using it for 3 years.
if Zaino proves to work magic on my car like everyone raves about, then Z6 will surely be on my list next
Try this stuff, it works miracles. No gimmick, it's essentially liquid sand paper. I've permanently taken out worse than what you've described. It will save you money!
if this liquid sand paper, or anything like T-cut it can be good and bad, taking off layers to remove my surface scratches, I'll be swirling the car out correct?
Status
