FX45 LMS Air intake heat shields?
Discussion in 'FX (03-08) - Engine & Drivetrain' started by fourfifth, Sep 9, 2007.
  1. fourfifth
    fourfifth Member
    65
    Boston, MA
    2009 infiniti fx35
    I was wondering if anyone with the LMS air intake has a heat shield.
  2. trainerKEN
    trainerKEN iS VIP iS VIP
    I don't have one but I've thought about having one made tho... in the LMS thread over at org., I know of at least one person that had one made and posted a picture...
  3. OP
    fourfifth
    fourfifth Member
    65
    Boston, MA
    2009 infiniti fx35
  4. trainerKEN
    hmmmmm interesting... no, I haven't seen that... but I'd be more concern about the hot air being suck'd in rather than the tube itself...
    but I was thinking more along the line of this:
    [​IMG]
  5. OP
    fourfifth
    fourfifth Member
    65
    Boston, MA
    2009 infiniti fx35
    Thats what I really want to put together. I'm going to look into both ways to keep air cooler. I'm going to try to make a heat shield this weekend. will post pics if I make some type of progress.
  6. RiceFX
    RiceFX Member
    10
    hmm.. im not sure why LMS didn't include a heat shield in the kit.
    But, quoting one of LMS' tech, "there was no visable difference when testing the kit with/without a heat shield on the Dyno"
    Take this how you like but i reckon LMS isn't THAT lazy to just ignore and not make shield. Nevertheless, i still have my speculations
  7. Chedman13
    Chedman13 iS VIP iS VIP
    9,167
    103
    Illinois
    I've read many posts where some say heat shields matter and others that say heat shields don't. Can anyone who knows for sure help answer this?
  8. fxlr8
    fxlr8 Staff Administrator
    17,956
    767
    California
    None
    Honestly I don't think a heat shield will help that much. When you think about it the heatshield is sitting right in the engine bay and if you look at heat shields they are usually not totally sealed, they have gaps and holes on the bottom.... etc. For it to work properly you would have to seal it off the best you can, where it has no option but to get the cold outside air, like in a fender or deep down below the headlight. What do I know though.
  9. fxlr8
    17,956
    767
    California
    None
  10. Chedman13
    9,167
    103
    Illinois
    very interesting. Since FX45 is 90mm, do I just buy that and customize it? Not sure what it means by special Bosch air sensor diameter of 90mm
  11. fxlr8
    17,956
    767
    California
    None
    Here is one on a 350z.
    You will probably just have to buy a maf adapter and connect it to that using your factory maf.
  12. fxlr8
    17,956
    767
    California
    None
  13. I was thinking about making a heat shield for my jwt pop charger. I know it comes with a side shield but i was thinkin to remake one similiar to stock where its all sealed and uses both factory air ducts. Any cons of doing it this way completely sealed? Any better ideas or improvements
