gchristopher9
Hey guys. So most people who do LED angel eyes use some kind of acrylic rod that is lit from both ends. Problem with them is that they aren't really all that bright, at least from what I've seen, and you can't get a complete circle. I had been toying with the idea for a while to use LEDs in direct view. Rather than to light up a rod of some sort, you would actually have a circuit board in the shape of a ring with some white LEDs mounted to it. when it turned on you would be looking straight into the light of the LED, so it would be a lot brighter. In my search i actually found a company that sells them, for something like 45 dollars PER RING. that would mean 180 bucks for 4. Plus from what i can tell they aren't voltage or current regulated, meaning that if your battery voltage drops down your LEDs would dim a little bit, probably not a big deal but if your running a big system and its hitting hard you might get some dimming on the rings at idle. So, being an electrical engineer my first thought was to just make some myself. I am going to work on laying out a PCB today, and pricing out the LEDs as well. I figured it would start a thread to gauge some interest on this. i will get back to you guys with pricing. As with everything else, the more people we can get to commit the cheaper they will be. I can promise you that it wont be anywhere close to 180 bucks for a set thats for sure. The big advantage over the CCFL tubes is that the LEDs aren't as sensetive to temperature, and will surely last A LOT longer. Anyhow, reply to the post if your interested and i'll keep you guys updated on my progress.
wow that is a long paragraph......but hey i'm an engineer not an english teacher
