:err::tears::ehh:
hmm, could there be a leak in your differential box and running dry??
---------- Post added at 02:48 PM ---------- Previous post was at 02:48 PM ----------
try cracking open the rear diff and see if any fluid comes out.....if not then UH OH
i am sorry i had to bring this thread out of the dead but my car is also making this loud loud sound now a days and then the VDC and SLIP lights come on almost instantly.
what surprises me is that it makes the "THUD" sound only from P to R and only when the car is parked on an incline. the lights go off once i restart the car in neutral.
it doesn't matter where it's facing on the incline or if its a cold start or a warm start, every time i shift to reverse gear, THUD and the lights.
the noise comes from right under my seat.
i have checked the tranny fluid a gazillion times and the level is good on the charging stick.
it's loud, that's what worries me, Is it really not a serious problem?
I used to have that loud knock when I shift from P to R on an incline. I was told by my friend that whenever you park your car on a incline or decline, first engage your E-brake hard and shift to N make sure your car at not moving at all after you release your brake paddle. Then shift it to P. It will be better for the tranny in the long run. That applies to most of the manual car as well. I have been doing that and found no more loud knock when I shift from P to R or P to D on either incline or decline. I am sure that will give the tranny less stress in the long run as well.
But I would definitely suggest you go get a ODBII scan to find out the error code of that VDC and Slip lights. That does not sound right.
