key light in dash???
Discussion in 'FX (03-08) - Electronics & Lighting' started by asherchy, Dec 13, 2007.
  1. asherchy
    asherchy Premium Member Premium
    1,676
    los angeles
    my dash keeps blinking at me that the key isnt in the car even though it is... blinks for a minute then goes away.
    im thinking that the battery in the remote is dying.. anything else it might be. when i change the battery is anything going to need to be reprogrammed or reset...
    thanks
  2. turbocad6
    turbocad6 iS VIP iS VIP
    8,341
    59
    brooklyn, ny
    the antenna for interior key sense is in the center console, so if you got your keys in a left pocket in a leather jacket or something it might be on the fringe of reception maybe, the battery also sounds like a possible suspect. it should just work the same after the battery change no problem.
  3. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Yea, make sure you change out the battery once a year just to be safe. Just replace it nothing else is needed.
  4. OP
    asherchy
    1,676
    los angeles
    i always put my keys in the same spot so im hoping its just the battery... havent replaced it since i bought the car and who knows when the previous owner changed it..
  5. Psiclne
    Psiclne Guest
    Its the battery - I had the same thing happen earlier this year. Change it out and everything will be fine
  6. OP
    asherchy
    1,676
    los angeles
    all fixed. just the battery
  7. rookie
    rookie Premium Member Premium
    2,201
    29
    Westminster OC
    Car:
    car
    I want a blinking key thingy. No tech for me, I'm low tech.
  8. Psiclne
    Psiclne Guest
    Glad you got it fixed asherchy! Was it tricky for you to get the iKey to open up??.....um cuz I didnt ;)
    You have crazy buttons on your remote - much more advanced then the tech package I must say......:err:
  9. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Thats an understatement!:err::p
  10. OP
    asherchy
    1,676
    los angeles
    ill trade you straight up rookie...
