Just want to change the headlight bulbs
Ok, I have read the how-to on removing the bumper, But my question is, Is there a way to remove the headlights without taking off the whole bumper..
I just want to install my 6k D2S bulbs and put the clear/amber turn marker bulbs on..
Sorry for the Newb question, I know on the Evo you had to remove the whole bumper just hoping i dont have to on the FX..Thanks for your time and help
TO install the D2S, you dont need to remove the whole f-bumper. You can simply unscrew the oem bulbs and install the d2s with the headlights still on the car. The ambers i am not sure
however if you want to remove the headlights from the car, then you have to remove the front bumper before you can remove your headlights
good luck modding! :smile:
you can change the HL bulbs and turn signals w/o removing the bumper.
it would make things easier if you removed you stock airbox. also I used a small mirror to help in seeing inside the h/l housing (to secure the locking "clamp")
should be a piece of cake.
*make sure the engine has cooled down
