FX35 Jim Wolf Pop Charger Question
Discussion in 'FX (03-08) - Engine & Drivetrain' started by imballin2day, Mar 20, 2008.
  1. imballin2day
    imballin2day Member
    151
    LA
    If I buy a Jim Wolf pop charger system can I run that intake with the stock z tube or should I get a stillen or lms ztube? Will the z-tube create a louder sound?
  2. Frankiago
    Frankiago Evo Troll Premium
    2,563
    IL
    Than stock? Yes. The baffles on stock intake do their job well.
  3. OP
    imballin2day
    imballin2day Member
    151
    LA
    Bump. I bought this and installed it yesterday. I want to buy a ztube. Will the LMS fit the popcharger perfectly? Is anyone running that setup?
  4. Richardim
    Richardim Member
    6
    SOKAL
    Juss installed a pop charger with z-tube and sounds amazing! the z-tube will make it louder and help in acceleration. not a big big difference but will notice at half throttle smoothness! thats all i can say! for the lms im not sure since i never installed one. on the z-tube i had to cut off the stock intake to extend it but its not hard at all. just cut and connect! GL! ;)
  5. jbaker1121
    8,938
    125
    Westchester, New York
    Car:
    09 FX50
    what does the pop charger actually do
  6. HumbertoCALI
    3,868
    South Gate, CA
    Car:
    2003 FX45 AWD
    Golan.
    Especially now. Make sure to reset your ECU so you can get the most out of your new mods...
  7. brown_fv
    1,703
    Toronto, On
    its the intake filter like the stillen cold air box.
  8. FxJojo
    FxJojo Member
    113
    Kuwait
    is the JWT Pop charger better than the LMS one(filter)? i just purchased LMS SRI which comes whith K&N filter i think and no heatsheild.
    i wanted to buy an intake system with heatsheild but they say that the LMS has the best tube and i like it.
  9. teknoboy66
    teknoboy66 Member
    90
    Washington, DC
    ok, so i searched and this ooooold thread seemed like the best place to ask this question.
    I've decided to put the jwt pop charger on, now, where the hell do I buy it from? I seriously can't find one place online that doesn't look sketchy.
  10. Chedman13
    Chedman13 iS VIP iS VIP
    9,168
    103
    Illinois
    Car:
    I buy direct from jwt.
    You can get it here for the FX35 with a heat shield:
    http://www.infinitipartsusa.com/par...rtInfo&PartID=437129&siteid=55&catalogid=3323
  11. teknoboy66
    teknoboy66 Member
    90
    Washington, DC
  12. teknoboy66
    teknoboy66 Member
    90
    Washington, DC
    got it and put it on yesterday.
    The sound at WOT is amazing!!
    sucks because I was hoping it would help improve my gas mileage and all i want to do now is floor the thing.
    Should I reset my ecu?
    I've heard lots of yeses and lots of nos so I'm on the fence////
  13. Logan
    Logan iS VIP iS VIP
    14,182
    116
    Seattle
    No need to reset the ECU really unless it is causing issues. After you get all the performance mods installed you think you will want (it never ends) then you can go for a tune, either by using a Uni-chip or an UPREV. That will gather up all the benefits of your mods (especially your breather mods) and you will see the payoff in more power and possibly better MPG's - if you can keep your foot out of it =)
  14. Dracula
    Dracula Premium Member Premium
    3,095
    77
    Hollywood, CA
    Car:
    2004 FX35 RWD
    Name:
    Andy
    the sounda loud? growls? , can u take a vid from outside neutral revs and obviously inside?
  15. teknoboy66
    teknoboy66 Member
    90
    Washington, DC
    normal driving and idle I'd say you don't hear it.
    When you lay on the gas, then the beast wakes up.
    I'll take some videos later today.
    My only other mod is a 5/16" motordyne spacer.
    I highly doubt I'll do anything else to the engine.
    I'm seriously considering H&R springs though.
  16. Chedman13
    9,168
    103
    Illinois
    Car:
    You won't regret the H&R springs -- do it!
  17. teknoboy66
    teknoboy66 Member
    90
    Washington, DC
    :) yeah yeah i know i will.
    I did have a question though regarding the delivery of actual "cold air" into the thing.
    Has anyone else cut a hole in the lower grill where i put the circle so that fresh air can actually get in below the filter or does everyone just rely on the "power duct"
    [​IMG]
  18. PMG 705
    PMG 705 Staff Moderator
    12,860
    289
    Chi-town
    Car:
    FX
    I think wasabiz did something similar to what you're proposing.. It shouldn't be difficult to execute with some ducting, but you'll also need to think about turbulence if you get the accordion type piping.
