FX45 Intake Options
Discussion in 'FX (03-08) - Engine & Drivetrain' started by Chedman13, Aug 28, 2007.
  1. Chedman13
    Chedman13 iS VIP iS VIP
    9,167
    103
    Illinois
    Any ideas for a FX45 intake?
    I could get an adapter plate to mount to the MAF sensor and just bolt that on instead of the OEM box and throw on a cone filter.
    I don't think I'd have the time to create a box to conceal it from the heat. Good/bad idea? Right now I just have OEM filter and OEM air intake.
    If not I'll just cross my fingers for the Jim wolf intake.
  2. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    If LMS has stopped carrying their CAI's for the FX45 then we maybe out of luck until someone else comes up with something.
  3. OP
    Chedman13
    9,167
    103
    Illinois
    The lean condition present with the LMS CAI prevented me from buying it. Another member was adamant about it and convinced me enough not to buy it. I'm having second thoughts of missing out on the group buy though.
  4. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    Ed, in reading my review I think you missed the part that said it was the combination of the CAI and TS flash. Also the model year of the FX was also mentioned. The 03-04 FX45 was safe from this lean condition (even with the TS reflash and LMS combo for these model years) because of the wider band used for the 02 sensors so there is a higher tolerance whereas in 05 this band was narrowed. But I also stated that if you have a CAI it would be safest to get a specific tune for your FX from TS when doing the reflash that accommodates the CAI.
  5. OP
    Chedman13
    9,167
    103
    Illinois
    I got my information from another member that mentioned my 03 without the TS flash was a lean condition and he told me it was proven by the CONSULT?
    Yes, I totally misread your post. Now I'm regretting missing out on the group buy for the 03 CAI. Oh well, thanks for putting that in layman terms. Looks like we have two FX45's looking for LMS intakes now=)
  6. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    Well good luck in finding one. I'm sure one will show up somewhere.
  7. da mayor
    da mayor Member
    dont worry im in the same put-- i want to put an intake on the FX45 2007 but nothing is out there.
  8. fourfifth
    fourfifth Member
    65
    Boston, MA
    2009 infiniti fx35
    Sorry that I grabbed the last one fellas.
  9. OP
    Chedman13
    9,167
    103
    Illinois
    http://www.weapon-r.com/english/index.php?main_page=page_2
    WEAPON*R COMPETITION PRODUCTS:
    180 SYLVESTER ST.
    SOUTH SAN FRANCISCO, CA 4080
    Anyone live near here? They can make custom intakes and once they have the dimensions, they should be able to duplicate it. If someone is near by they can take exact measurements and test fitting vs sending out pictures w/ measurements.
    Any volunteers?
  10. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    Someone with a 45 volunteer.
  11. fxlr8
    fxlr8 Staff Administrator
    17,961
    770
    California
    None
    what about your air sensor?
  12. OP
    Chedman13
    9,167
    103
    Illinois
    I was thinking of a simple solution, kind of like the Z-tube for the FX35.
    Straighten out the air flow and add a cone to the end, that shouldn't cost much. They also have "ram air" kits where it seals the cone filter and you can directly put the tubing down to the air inlet. Just a thought.
    The Air Sensor, I'm sure they can easily create one if they don't have one already to fit our MAF Sensor. They have several MAF sensors, one being nissan. I have no idea if it's the same. Either way, I have no issues re-using my MAF Sensor tube and just adding aluminum tubing the straighten out the flow.
    There has to be a FX45 in the area! I'm sure it'll take them under an hour to get the measurements they need... Straighten out the tube from the throttle plate to MAF Sensor w/ holes/nipples for stock tubing, MAF Adapter plate and maybe a split into a Y to do a dual intake, one towards the ram air and the other pointed downward?=)
  13. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    The LMS MAF sensor location on the intake was a bit close to the cone. If someone does this make sure the sensor location is identical to the oem intake.
  14. OP
    Chedman13
    9,167
    103
    Illinois
    99-04 Nissan Frontier 3.3L V6 Heat Shield Intake R
    Chrome finish 3.5"" pipinghttp://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&sspagename=STRK%3AMEWA%3AVRI&viewitem=&item=200152173631&rd=1
    Maybe we can modify this?
  15. OP
    Chedman13
    9,167
    103
    Illinois
  16. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    Doubtful. Looks to big and too short. I don't think the heatsheild will work either.
  17. Psiclne
    Psiclne Guest
  18. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    That's for an 06 Will, Ed's looking for an 03 version. But someone with an 06 should pick this up in a hurry!
  19. Psiclne
    Psiclne Guest
    Opps - sorry. I remembered someone looking for one - just didnt recall the year and I was in a hurry to post it so someone can jump on it. :shame:
  20. OP
    Chedman13
    9,167
    103
    Illinois
    No worries, thanks for the heads up. I think someone from Korea was looking for one? Was it RiceFX?
