How Cold is 2 Cold For FI???
Discussion in 'FX (03-08) - Boost, Track & Tuning' started by Keemo, Aug 3, 2007.
  1. Keemo
    Keemo Premium Member Premium
    So, we all know that cold air allows the engine to breath better with positive results. But how cold is too cold for a set up like a TT or Superchager???
    You see, I live in Edmonton with the Huskies and Sleighs that were mentioned in a previous post ;) and in winter it will get to -30!!! Is this way too cold for this set up in a daily driver??? I'm also concerned about all the tubes and hoses that are needed for this with freezing and cracking. Is this worth it??
    Or should I leave all the fun stuff to you Cali guys?:frown:
  2. brown_fv
    im sure it will be ok. i know of this one guy with a white STi limited in edmonton who is just modded the hell out and hes doing ok...only problem is that his front lip always breaks in the winter because it acts like a snow plow in the snow lol
  3. Frankiago
    Frankiago Evo Troll Premium
    2,563
    IL
    Shouldn't be a problem.
  4. da mayor
    da mayor Member
    i just got my G35 sedan FI'ed and it hates these hot weather days and humidity. I notice a big difference when it's 60 degrees at night w/ low humidity especially on the highway. I can't wait till it gets even colder
  5. OP
    Keemo
    Then I guess the rule still applies!:biggrin:
    Thanks for answering a nubee question guys.
    And look out dog sleighs! :rofl:
  6. Frankiago
    2,563
    IL
    The turbo guys LOVE cold weather, especially dry, cold weather.
    The only issue there is the ground then... traction isn't as good when it's colder.
  7. OP
    Keemo
    Actually, you make a good point that I never thought of.
    Hard, cold rubber against cold hard pavement = not good traction :eek:. And some mornings when you first get going, there is actually a flat spot on your tires from where the vehicle has been sitting all night, frozen flat. But of course you most likely wouldn't be gunnin it until the engine has had a chance to warm up, and the spot rounded off from it or then I'm sure you'd be asking for something to get *#$%ed up.
  8. Frankiago
    2,563
    IL
    Anybody remember a rule of thumb for what outside temp equates to HP wise? Drop in temp XX # degrees F = ?? HP gained... I'm sure that formula would be quite different between FI and NA?
  9. gto
    gto Track Ready Moderator
    16,622
    623
    Los Angeles, CA
    05 FX35 RWD
    Now that's a damn good question. I think that's what Kemmo's really looking for an answer on. I myself am curious. Who's our engineer on the boards?
  10. Ed@Pepe
    Ed@Pepe Member
    15
    Keep in mind that whenever you drop air temperature, you increase air density. When you increase the density of the air the motor breathes, you have to allow for more fuel, because there is more oxygen for every breath the motor takes. Essentially, colder ambient temperatures equate to a leaner air/fuel mixture, and more power. This is good to a certain point, then you need to compensate and add more fuel to safely run the motor.
    -Ed
  11. Psiclne
    Psiclne Guest
    Turbos love cold air - I wouldnt worry too much.
    When I had my GMC Syclone - I used to take it up to Mammoth and man it was great compared to the LA weather. I didnt even have to boost for the blow off to sound off.
    When ever I made the trip I would set it for 15lbs.....:rolleyes::rolleyes::rolleyes::biggrin::biggrin::biggrin:
  12. OP
    Keemo
    I forgot about this thread.
    Well, it snowed last night, so it's definitely cold out.
    It'd be cool to find out what the technical info would be for temp=hp. And lower alt is better than higher altitude right?
    After my first couple of mods, I can see myself getting carried away...perhaps ending up with F/I of some kind, so it's good to know.
    Thanks for all the input guys.
  13. Chedman13
    Chedman13 iS VIP iS VIP
    9,168
    103
    Illinois
    Nice to have another expert on the forums!
