Headlights
dopie
Premium Member
Premium
any way to reenforce the head lights glues?
cause when i ovened it to crack my headlights open to fix my AEs
the next day it rained and what i found the next day was that there was water inside the housing wehre the clear plastic part was.
so i was wondering is there any way to seal it off better?
thnxs jeff
jw though have any of you guys go this problem when you guys cracked your head lights open?
thnxs jeff
havent had this issue with the fx lights per se but have in the past with other headlights...thats why I always use the permatex everytime, despite some people claiming that the sealant that is already there is enough...
I'm not a fan of silicone for this, makes a mess if you have to open them again & is not so compatable with the original glue. also I think the gasses from that much silicone can cause issues inside the lense... silicone doesn't soften if you heat it up too, not the best for this all around...
use something like this: http://www.technologylk.com/product...eld-Ribbon-Sealer--1-4-Round--15-ft-Roll.html much better & compatlable with the original glue, will soften when you heat it, much closer to the original headlight sealer..
