Has Anyone Lowered Front Only?
Discussion in 'FX (03-08) - Wheels & Suspension' started by Kkrogers, Oct 25, 2007.
  1. Kkrogers
    Kkrogers Member
    55
    Cottage Grove, OR
    I was wondering if it is even possible to lower just the front? I kind of like the way the back sits, the car just needs leveled out some.
    Thanks,
    K
  2. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    You can have your stock springs recoiled a little lower. Or just get eibachs or H&R's and use just the fronts.
  3. Frankiago
    Frankiago Evo Troll Premium
    2,563
    IL
    Somehow I don't think he means quite THAT low in comparison :p
    What do you mean stock springs recoiled? You can always clip off a portion of the front springs... not recommended but it's an option.
  4. fxlr8
    fxlr8 Staff Administrator
    17,990
    781
    Car:
    Other
  5. rookie
    rookie Premium Member Premium
    2,201
    29
    Westminster OC
    Car:
    car
    I cut the spring mount in the rear with the H&Rs when we first put them in. Leveled it out nicely since we cut the front springs. :D
  6. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Yes, cube that is an option to have the springs recoiled to lower the ride. LMS can do it here if I wanted but I didn't know this until I already did the eibachs. There is a special tool to do this but I you have to call and ask around to some performance shops.
  7. Psiclne
    Psiclne Guest
    +1 LMS talked to me about this also - but I got a good deal on the Eibachs so I just did that. You should call LMS up if you want more details.
  8. Ed@Pepe
    Ed@Pepe Member
    15
    While you can definitely pull it off, I wouldn't personally reccommend using OEM springs on the front and aftermarkets on the rear. The FX's suspension is engineered for certain weights and balance, and if you change the spring rate in ONLY the rear, the entire suspension geometry changes. It may be able to be done, but it certainly undermines a lot of relevant design relating to the suspension, feel, and balance of the FX.
    -Ed
  9. OP
    Kkrogers
    Kkrogers Member
    55
    Cottage Grove, OR
    Thanks for the info guys. Actually when I got home last night and looked at it some more in the level garage, I realized it needs lowered all around. I am going to order the H&R's soon, but they are back ordered for 8-10 weeks I guess!
    Thanks,
    K
  10. Z33_2_FX35
    Z33_2_FX35 Member
    270
    Dallas Texas
    Lowering just the fronts? I would assume to a certain degree your VDC will not like it. Plus I assume your spring rates front and rear would be all off.
