Can we get more output from our Blows subwoofers?? I think we can....The following has been done on the Mazda 6 website to an overwhelming success. Hundreds of these have been sold and everyone has great things to say. The bass output level goes way up, and gets rid of some of the midbass making way for a much better lower end.
First of all I need to say this is from a Mazda6. But I can't see why someone here who knows electrical boards/circuits/resistors can't get this to work for us. Plus its great because no wires are cut...only tapped into.
DISCLAIMER:
Wire colors are not the same and this has not been tried yet on our systems. ANY thing you do is on your own..I am not responsible !!
this is from my other website:
Connections (on my speed6, may be different for other cars)
12v power can be tapped on the amp harness: orange wire
ground: tap black wire
in+: cut purple wire, connect harness side to preamp input, amp side to preamp output
in-: tap yellow wire
Parts Needed
approx $12-$20)
-breadboard (solderless) or perforated board (solder)
-thin gauge wire
-15K ohm resistor (1/4W or 1/8W)
-4.7K ohm resistor (1/4W or 1/8W)
-1uF capacitor (>25V)
-100uF capacitor (>25V)
-LM741 op amp
-electrical tape
i suggest you get a breadboard if you're new at this. from radioshack, total cost was ~$20. i had to buy a 50 pack of resistors and breadboard which doubles the costs of 808's original $10 estimate.
ok, here's an attempt at walking you through this. please note the colors in the attachment because the colors correspond to the wire color you will need to splice or tap. the only wire that needs to be spliced will be the purple wire. all the other wires just need to be tapped.
please note the 100uF capacitor direction. the capacitor i used has an arrow on it. it indicates the side of the capacitor that connects to the negative (-). the 1uF capacitor is usually bidirectional.
i've also drawn out an example of a breadboard in case someone doesnt know how to use one. if you look at the drawing you'll see the lines labeled 1,2,3,A,etc. those lines means that all the points on that line connect. so everything on line A is connected and everything on line B is connected, etc. all the pts on the GROUND line are connected as well.
Now, is this possible or will it do anything for us? The person who developed this circuit even has a new one with a gain level and eq. Here is his completed circuit board:
http://go808speed6.ulmb.com/home.htm
I'm going to buy this and try it on my 6....but wondering why this couldn't be hooked up to the FX? He's out of stock of the new ones now, so have to wait and see....
DISCLAIMER:
Parts Needed
-thin gauge wire
-LM741 op amp
-electrical tape
