G35 extension pipe
Discussion in 'FX (03-08) - Interior & Exterior' started by CycoDK, Sep 25, 2007.
  1. CycoDK
    CycoDK Member
    52
    Qatar
    Does anyone have a picture or a part number for the G35 extension pipe for nismo exhaust??:)
  2. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
  3. silverFX
    silverFX Member
    37
    Newburgh, Indiana
    Sold my 2003 FX35
    How long is it?
    How long is this extension? The wheels are turning! ;)
    can this extension be used on any 350Z y-pipe or is it Nismo specific?
  4. Chedman13
    Chedman13 iS VIP iS VIP
    9,167
    103
    Illinois
    I believe the extension is used because the mid-pipe is shorter on the 350z. You can use any 350z y pipe IF you have RWD.
    So if you have a 350z mid pipe, for the most part it should be able to be used with the g35 extension though you may have a mismatch in tube size. G35 extension is 3.00" where others can be 2.5" I had no issues with this mismatch though. No resonance, no rasp, etc...
  5. silverFX
    silverFX Member
    37
    Newburgh, Indiana
    Sold my 2003 FX35
    Here is what I am thinking.
    here is my idea. I want a y-pipe for my AWD FX35. I want 2.5" inlet and 3". I have found many 350Z y-pipes on ebay and else where that have those diameters. I was thinking of buying two extensions and putting them on the front of the y-pipe. Then buying a 350Z mid pipe for the back of the y-pipe. Now I would have to look for a Y-pipe that had a larger y (JIC).
    http://www.350z-tech.com/zwiki/Y_Pipes
    What do you think about that idea?
  6. Chedman13
    9,167
    103
    Illinois
    Never thought of that. Note that our outlet from the cats are 2.25". Trying to mate this to a 3.00" extension piece should be fine as long as it bolts up. Granted my 3.0" y pipe mated to my 2.5" mid pipe, it is possible all the bolts line up. No one has tried, so you would be the first to mate a 2.25" to a 3.00"
    You're running into a lot of mis matches, 2.25" cat out to 3.00" G35 extension to 2.5" y pipe dual in to 3.0" y pipe out.
    You're adding weight as well with the extensions. Moving the y pipe further back, it may still not clear the AWD case.
    Not discouraging you as I'd love to see this done, but just know the risk of trying it. If this does work, could open a lot of doors for other FXers.
  7. silverFX
    silverFX Member
    37
    Newburgh, Indiana
    Sold my 2003 FX35
    May try it.
    I may just go ahead and try it. If it does not work i guess I will just sell it here on the Scene.
    The headers on my avatar have an outlet of 2.5".
    I think I will look for a used 350Z y-pipe to keep the cost and risk down.
  8. brown_fv
    that just might work...using a g35 extension on either side will push the y-pipe back (like you said) and it just might give clearance for a g35/350z specific y-pipe to be used.
    going from the outlet of your cats (2.25 or 2.5) to the 3" of the g35 extension wont be a problem, but hopefully you can get a y-pipe that has an inlet of at least 2.5". you might lose some low end power with the increased piping size though but im no expert.
  9. gto
    gto Track Ready Moderator
    16,497
    528
    Los Angeles, CA
    05 FX35 RWD
    Never go bigger to smaller on the way out the back, & 3" single has not shown to lose anything on the low end. stock cats are the main kink in the system. Unless you change that out & headers, ya wont lose anything.
    Chedman, you have a smaller midpipe than your Y? Why did you choose this setup?
  10. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    Why not just get the y pipe Chedman found in Taiwan which already fits the AWD FX.
  11. Chedman13
    9,167
    103
    Illinois
    I didn't have a choice, only had 3.00" outlet to my 2.5" hks mid pipe. I could have used a reducer to make the transition more smooth, but after the y pipe was bolted, i listened to it and drove it around and decided I didn't need it. Mabye I lost some power, but if so it would be offset by the gain from the y pipe in general. But I doubt I lost much if any as there is no rasp or resonance so loss would be at a minimal.
    My goal is to maximize performance but to an extent. My trade off here was to find something cheaper than the Stillen (which happened because I bought a used HKS rear section), but 100% bolt on. For some reason, my #1 priority was to have something 100% bolt-on or else I would have gotten the Stillen or Nismo.
    I'm very happy with my set up and wouldn't have done it any different. HKS sounds and looks great with the Y pipe. But I do agree, the 3.00" to 2.5" might scare people off, but after I tried it, doesn't bother me a bit.
  12. gto
    16,497
    528
    Los Angeles, CA
    05 FX35 RWD
    OK, understood . . but sounds like the HKS would have been the PERFECT Y for you.
    Glad there's no rasp :rolleyes: That could have been the likely result of yur setup.
  13. Chedman13
    9,167
    103
    Illinois
    They did have a 2.5" out that UTR sold two of them. Unfortunately I couldn't get my hands on these.
    I'm just happy I have a rare y pipe=) I can always go to nismo later on if I decide to and not have a mismatch.
  14. gto
    16,497
    528
    Los Angeles, CA
    05 FX35 RWD
    Nismo, no, it's also a 3". Best match for you & that midpipe is that UTR 2.5 or the HKS.
  15. Chedman13
    9,167
    103
    Illinois
    Sorry let me clarify. I currently have a 3.00" y pipe outlet. If I got the Nismo like Pierce I would not have a mismatch.
    Yes I agree for my current mid pipe of 2.5" , the 2.5 UTR y pipe outlet is optimal. HKS y pipe is optimal if I had RWD as you mentioned.
  16. gto
    16,497
    528
    Los Angeles, CA
    05 FX35 RWD
    all clear
  17. silverFX
    silverFX Member
    37
    Newburgh, Indiana
    Sold my 2003 FX35
  18. OP
    CycoDK
    CycoDK Member
    52
    Qatar
    Is this extension in G35 coupe or the sedan??:confused:
  19. Dr.2K
    11,683
    9
    Santa Clarita, CA
    2005 FX45
    You still have to extend the tips. All the 350z/G exhausts will work with the RWD fx35 but you will still need to extend the tips and depending on the exhaust, need the G35 extension piece.
