3.5L FX Slips in to neutral when driving,or doesnt change gears? HELP
Discussion in 'QX70 Engine & Drivetrain' started by Mr Fx, May 30, 2013.
  1. Mr Fx
    Mr Fx Member
    52
    NEW YORK CITY
    When driving at 20 or below mph when pressing pedal i am getting high rpm and not shifting properly whats the problem?
  2. PMG 705
    PMG 705 Staff Moderator
    12,858
    289
    Chi-town
    FX
    You'll have to be a bit more descriptive.. Is it actually in neutral or on a higher gear and thus slow to respond? Does it eventually downshift or go in gear? Is it a rough switch etc...
    TapaTalkin'
  3. OP
    Mr Fx
    Mr Fx Member
    52
    NEW YORK CITY
    Slow to respond, and down shifts hard as well when stopping.
  4. la_fx35
    la_fx35 Staff Moderator
    20,182
    1,117
    Chicago
    2003 FX45
    Andy
    Check transmission fluid level?
  5. neva4self
    neva4self Member
    705
    2
    Queens, NY
    2009 FX50
  6. Fire0nic3FX
    Fire0nic3FX Member
    885
    4
    Car needs a software update like what neva4self said
    But its not actually shifting into neuetral. If that were the case you have a really serious problem lol
  7. 2010fx35
    2010fx35 Member
    642
    Oregon
    2010 Fx35
    I had the same problem about a month ago. I was just driving and it felt like the car couldn't find its gear and was in neutral. Accelerating just rose the RPMS. I tired manual shifting into gears but nothing happened so I had to pull over, tried moving the shifter up to park and back down to drive but nothing happened until i turned the car completely off and back on. It hasn't happened yet after getting the updates like people suggested. I also had rough shifting and it feels a lot better now. Also someone mention to me it was like a fail safe for the car. Pretty scary when it happens I was lucky i was on a local street.
  8. neva4self
    neva4self Member
    705
    2
    Queens, NY
    2009 FX50
    No prob. Mr FX unfortunately most of us with the early model 2nd Gens have had this issue and most have had it dramatically improve with the ecm/tcm update. As a matter of fact the updates are different and not as current for the FX50 and I still get a ridiculously uncomfortable harsh downshift when I brake super hard while traveling at high speeds. I hear the FX35's most current update addresses most of the shift response issues though. Good luck with it.
  9. Fire0nic3FX
    Fire0nic3FX Member
    885
    4
    hope you get it sorted!
  10. OP
    Mr Fx
    Mr Fx Member
    52
    NEW YORK CITY
    Thanks everyone i am going to get this update as soon as possible. Best community on infinitiscene hands down!!!!!:good::iS::smile (2):
  11. 148blast
    148blast Member
    3
    22204
    2010 FX35 AWD
    Phil
    Mr Fx - any update on this? Have you had any issues since 2013? My 2010 FX did the same thing the other day (engine would rev but car would not accelerate) and wondering how you resolved this. Thanks!
  12. 2010fx35
    2010fx35 Member
    642
    Oregon
    2010 Fx35
    Before my incident I got my ecu updated due to rough shifts. And about four months ago it happened again. Fluid levels are good and all.
  13. 148blast
    148blast Member
    3
    22204
    2010 FX35 AWD
    Phil
    Thanks for the reply! So it's still happening and no idea what's causing it?
    How often does it happen now?
  14. r1cky
    r1cky Member
    37
    71
    Los Angeles
    2010 FX35
    Ricky
    any updates with the transmission problem? today the same thing happened, was driving in traffic, and all of the sudden sounds like it popped out of gear and stuck in 1st gear, won't shift into 2nd... had to pulled over, restart the car then it drives fine (2010 FX35 w/ 132000 mi, just changed the transmission fluid at 120k)
  15. nima
    nima Premium Member Premium
    432
    51
    Toronto, CA
    2010 FX50S
    For those who have replaced their transmission fluid and are having issues.. have you guys actually made sure the correct fluid was used? Using the wrong fluid can really screw with the grearbox - it'll be a case of too much grease not enough grease. Im talking from experience with my 97 Toyota Land Cruiser, ended up with a transmission rebuild fully covered by the dealer because it was their fault. But our cars as most have experienced, has issues with the software mostly. Does anyone know the latest software version #?
  16. r1cky
    r1cky Member
    37
    71
    Los Angeles
    2010 FX35
    Ricky
    the tranmission fluid was serviced by the dealer with nissan s-matic trans fliud but im not sure what software im running...
