FX seems so slow all of a sudden...loss of power...?
Discussion in 'QX70 Chat' started by brown_fv, Aug 16, 2007.
  1. brown_fv
    for the past few nights every time ive been driving my FX it seemed to be a lot more sluggish and a lot slower than it usually is...when i hit the gas i feel like there is no low end power whatsoever and something that i really noticed is that i barely hear the whistle of my pop charger that i usually do. the filter doesn't need cleaning as i only have around 5000km on it.
    when i turn on my car in the garage i hear this faint high-pitched sound...could it possibly be an air leak from my plenum? i remember a few nights ago i was just re-tightening the bolts...maybe i broke one? would an air leak cause a noticeable loss of power the way i am feeling it? it honestly feels slower than stock:frown:
    i am due for service in a little bit, but i am very hesitant to bring it up as i am modded and there are not so many modded cars here (i might be one of the only modded FXs in the city)
    btw if it means anything, when i turn on my FX the RPM shoots up over 2000 before settling (cant remember if it did that before)
    thanks.
  2. A leak could be your problem or it could be something simple like bad gas. If you are hearing a hissing noise that wasn't there before I would start checking leaks. BTW what's the mileage on your FX?
  3. OP
    brown_fv
    how would i go about checking for leaks? my mileage is currently almost 25,000KM and im due for service at a bit less than 26,000KM
  4. fxlr8
    fxlr8 Staff Administrator
    17,961
    770
    California
    None
    Yes a leak could cause sluggish power due to the un-metered air entering the engine. I always check for leaks by spraying some fuel injector cleaner around the areas I think I have a leak and if the idle changes when you spray you have found your leak.
  5. OP
    brown_fv
    if i want to try this, should i first turn on my car and while it is already idling just spray a slight amount over the area (or areas) where i think a leak could be? how will the idle change? will the fuel injector cleaner get sucked in?
  6. fxlr8
    17,961
    770
    California
    None
    Here is something I pulled off the web
    Yes, start the car first and at idle do the above
  7. OP
    brown_fv
    ok, i got some fuel injector cleaner and did what you said. before i did that i loosened me plenum bolts then torqued them back into place. at idle when i sprayed the fuel injector around some of the bolts or areas i thought could have a leak i did not hear any change in idle. my gas is almost empty so ill fill her up at a different station today and see if maybe there was a batch of bad gas or something.
  8. fxlr8
    17,961
    770
    California
    None
    bump for an update
  9. OP
    brown_fv
    well ever since then ive noticed its not as "sluggish" as it was before but still feels like something is missing. i dont hear that noise i heard coming from the engine before, i guess i should have used the fuel injector cleaner before i re tightened all the bolts, but im pretty sure one or more were loose. when i turn on from a cold start engine shoots to no more than 2000 rpm or so and then settles (before it was going well past 2000rpm). i also hear my pop charger again...will try to do some 0-60 tests (estimates as i dont have a g-tech or anything) and a bunch of WOT pulls to see if everything is back to normal.
