FX35 Fujita CAI
Discussion in 'FX (03-08) - Engine & Drivetrain' started by FX_Allen, Dec 15, 2007.
  1. FX_Allen
    FX_Allen Member
    640
    California
    Has anyone here used fujita intakes for their FX35? curious to how well it performs... thx ;)
  2. brown_fv
    1,703
    Toronto, On
    I think some people on the .org tried it...i think its like the injen intake.
  3. OP
    FX_Allen
    FX_Allen Member
    640
    California
    is that good or bad? more HP with more mpg or loss of mpg
  4. brown_fv
    1,703
    Toronto, On
    Gains will probably be similar to other intakes, although that particular intake has no heat shield at all...MPG should go up because the engine breathes better, although if you drive harder it obviously wont go up :LOL:. id shoot a PM over to da mayor...i believe he used to have the injen intake (same design as fujita) on his FX35 before he sold it...maybe he can tell you a bit about his experiance with it.
  5. OP
    FX_Allen
    FX_Allen Member
    640
    California
    Curious... but if i get the SRI (it has no box) Will there be any consequences in the rain?
  6. brown_fv
    1,703
    Toronto, On
    you will have no problems because the SRI is too far up for any water to get into contact with the filter...that would only happen with a CAI but the newer ones have "bypass filters" or whatever to help eliminate water getting into the intake tube.
  7. Psiclne
    Psiclne Guest
    Yes, if you drive around with no hood on......
    No issues Allen. many FX'ers are running SRI - not to mention all the other types of cars. Plus when does it really rain here in So Cal??? Like 3x times a year?
  8. OP
    FX_Allen
    FX_Allen Member
    640
    California
    HAHA UR SMART PSCLINE
    but thx... tho... and yea never rains... cool FUJITA HERE WE COME! after new years i will order... ^_^
  9. Krayzie
    Krayzie AĆ©rospatiale
    795
    Vancouver, BC
    yup, like everyone has said so far...you shouldn't have any problems. I live in Vancouver and it rains here 9/10 days and my engine bay doesn't even get dirty from the rain:LOL:
  10. mtbfx
    mtbfx Member
    592
    monterey park
    just got mine and installed it earlier. the rubber hose to connect the pipe to the throttle body is a pain to install. i end up using the stock hose and clamps. the fit is not as perfect, but was able to tighten everything. i already started and did a little driving and it seems ok. this should be ok right? anyone else using fujita and able to use the supplied hose?
  11. Psiclne
    Psiclne Guest
    I think FX_Allen is the only one using the Fujita.....he might be able to answer your question:err:
  12. mtbfx
    mtbfx Member
    592
    monterey park
    thanks. the silicone hose is smaller vs the stock rubber hose. but it looks like the whole thing is secure in its place.
  13. fxlr8
    fxlr8 Staff Administrator
    17,983
    777
    Car:
    Other
    Sometimes heating up the silicone or using a little dishsoap can help get it on.
  14. OP
    FX_Allen
    FX_Allen Member
    640
    California
    dont heat the silicone
    its a pain in the ass... but i got it on... i can help u out fujita gave me a quick installer tool for it...
    u should put the hose on the manifold clamp it and then install the intake into the hose... the intake mf should be a hair thin spaced from the intake... = )
  15. mtbfx
    mtbfx Member
    592
    monterey park
    i guess ill try again with a little grease (acc to fujita). if not, ill get a slightly larger hose.
  16. fxlr8
    17,983
    777
    Car:
    Other
    What happens if you do?
  17. mtbfx
    mtbfx Member
    592
    monterey park
    curious about that too.
    a noob question here. any grease should be ok? i got a little dielectric grease around here.
  18. fxlr8
    17,983
    777
    Car:
    Other
    I haven't heard of using grease but I have heard of using a tiny bit of dish soap to help slide it on. After awhile the dish soap will completely dry leaving a non greasy surface.
  19. mtbfx
    mtbfx Member
    592
    monterey park
    ok the grease didnt work. i left the stock hose for now since it works. allen, let me know if i can borrow that tool to install it. ill also look for something cone shaped to stretch that stubborn hose before installing again. any other ideas?
  20. HumbertoCALI
    3,868
    South Gate, CA
    Car:
    2003 FX45 AWD
    :hmmmm2::hmmmm::dontknow: he can't seem to be found man.
