Front door, hatch stopped unlocking
Discussion in 'FX (03-08) - Interior & Exterior' started by mtbfx, Jan 21, 2008.
  1. mtbfx
    mtbfx Member
    592
    monterey park
    looks like it is time for new actuators or whatever mechanism it has. few days ago the front passenger door stopped unlocking but can be operated from the inside. earlier today, the hatch wont unlock via remove or driver door controls. sucks. waiting for a quote from west co nissan and may check glendale infiniti too.
  2. OP
    mtbfx
    mtbfx Member
    592
    monterey park
    i tried unlocking while car is on. the door still doesnt unlock, however, the hatch opens. i tried this multiple times. looks like actuator for the door, but unsure about the hatch. gremlins? any ideas?
  3. BTLFED
    BTLFED Member
    137
    Woodstock GA
    Car:
    2006 FX35 AWD
    The latch going bad on the hatch and not letting it unlock is a farely common occurance as is the door lock actuator. We actually stock the hatch latch, but the door can take a couple different ones.
  4. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Mike, how old is your FX? I thought it was fairly new. Actuator going bad already?
  5. OP
    mtbfx
    mtbfx Member
    592
    monterey park
    mine is an 03. its at the dealership now, waiting for a quote.
  6. OP
    mtbfx
    mtbfx Member
    592
    monterey park
    just got it done. they replaced the door actuator and everything is now working fine. at a total of $500 including labor. there goes a few future mods.
  7. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Dam, $500.00!!! Wow that is a hefty price tag. How long are those actuators supposed to last?
    But man, from the the looks of your FX Mike I would have never thought of it as an '03! Looks so dam clean, keep it up.
  8. OP
    mtbfx
    mtbfx Member
    592
    monterey park
    the part was about 260 and the rest is labor and tax. the words "ext warranty" was on my head as i was making the payment.
    another rep saw my ride and thought my fx was newer than 03 and that the work was under warranty. i wish.
  9. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    I think LMS would have been cheaper for the labor. Part cost would have been the same tho.
  10. OP
    mtbfx
    mtbfx Member
    592
    monterey park
    things are just too hectic and i was in a "get it done now" mode. im sure it would have been less.
    lets just say this is my latest mod :LOL:.
  11. MASSIVE
    MASSIVE Member
    188
    Maryland
    I'm kinda havin the same problem with my passenger door and the rear driver door. I was wondering if it would just be something that would be correct with an installation of an alarm system. Does anyone know if you still use the stock actuator when installing an alarm system or would it be replaced?
    Not sure cause I never installed a alarm system in a car before.
  12. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    What kind of problem are you having?
  13. MASSIVE
    MASSIVE Member
    188
    Maryland
    Well I still have the OEM alarm system, the standard lock and unlock doors and panic button. When I'm going to unlock the car and throw my work bag in the back seat the door, sometimes, doesn't unlock. After hitting the lock and unlock button a few times it will finally unlock. Same thing happens with the front passenger sometimes.
    I want to add an alarm system to my car, but if I have to replace the bad actuators, if thats what the problem is, then I can forget adding any mods anytime soon.
    I got a oil change coming up this Monday, I'm going to talk with the dealer rep then to get an idea of what the problem could be and how much.
  14. turbocad6
    turbocad6 iS VIP iS VIP
    8,341
    59
    brooklyn, ny
    weak actuators are not that uncommon with a lot of cars really, they do go after a while. about the only thing you could do is open it up & make sure nothing is causing any added resistance in the linkages... don't know if your car was ever repaired but body shop dust can acumulate on inner lubricated stuff & mix with the grease that was a lube & kinda make it like a paste instead, causing stuff like this. a bent or out of place linkage rod can make resistance too. maybe a long shot but might be worth at least looking at... if your fx is a virgin then it's gonna be the actuators themselves really though...
  15. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Yea, I agree with Turbo. I suggest having the dealer look at the actuators before looking at any after market alarm systems.
  16. turbocad6
    8,341
    59
    brooklyn, ny
    oh yeah, when an aftermarket alarm is installed it is just connected to the oe door lock wiring & simulates a button press, they do not install actuators with an alarm, it uses the oe actuators, unless the car didn't have power locks to begin with. aftermarket piggy back actuators are not a good option, better off just replacing the oe actuators...
  17. ABETRMAN
    ABETRMAN Member
    186
    Washington
    Car:
    2004 FX35 RWD
    Name:
    Johnny
    Dr.2k, what is LMS? I believe I may be suffering from the same problem.
  18. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    LMS = Luxury Motor Sport. They are located in Monrovia in San Gabriel Valley. Close to Metro Infiniti.
    Talk to Steve the owner and tell him you are form the FX forum and Pierce or Will referred you there.
  19. ABETRMAN
    ABETRMAN Member
    186
    Washington
    Car:
    2004 FX35 RWD
    Name:
    Johnny
    Thank you Dr.
  20. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Glad to help out a fellow FX'r :biggrin:
