FX35 Final Gears for the FX?
Discussion in 'FX (03-08) - Engine & Drivetrain' started by djdorifto, Sep 14, 2007.
  1. djdorifto
    djdorifto Member
    14
    Orlando/Melbourne, Fl
    One great mod for the S2000 is a higher Final Gear Ratio... Its not really adding horsepower to a car, but it feels like it... Can after market final gears for lets say from a 350z, would they fit in our rear diffs?
  2. rookie
    rookie Premium Member Premium
    2,201
    29
    Westminster OC
    Car:
    car
    RWDs come with 3.3 open. AWDs come with 3.7 open. I have a RWD, but am using a 3.7FD and a ATS LSD.
  3. OP
    djdorifto
    djdorifto Member
    14
    cool, I was doing some searching for Final Gears but they were all only for 6spds... Where did you get your ATS LSD?
  4. rookie
    2,201
    29
    Westminster OC
    Car:
    car
    I believe there are only a few LSDs that can be added to the 3.3FD, maybe 1 or 2 if I recall correctly. Most of the LSDs are designed around the thickness of the 3.5 3.7 3.9 rings.
    I got a second pumpkin from a G driver who was adding the 3.7 to a 3.5 with vLSD. Swapped out the companion flange and it was a direct swap. Are you looking for a RWD or AWD FX?
  5. OP
    djdorifto
    djdorifto Member
    14
    RWD is what I'm looking at...
  6. raymond
    raymond Member
    1,283
    2
    Netherlands
    Car:
    FX35 RWD
    Something else.
    Some of the guys here advised me to go for a 3.9 Final Drive.I have to questions concerning this:
    1) will this effect the topspeed to much....??
    2) on your website it doesn't say any aivalable for a automatic (350Z)
  7. Z1Performance
    Z1Performance Member
    166
    Smithtown, New York
    you would need to buy the differential from a manual car (stock or aftermarket diff) as well as new output shafts, bearings, etc to make it all work. This is true of the 3.7, 3.9, 4.08 and 4.3 - they are all designed to work with the manual transmission LSD, which is different from the automatic LSD
    yes it reduces top speed - but you're driving a luxury SUV...so top speed isn't exactly high on the list of attributes in the first place :) Seriously though, there are a bunch of gear oriented calculators online. If you plug in the weight, power, wheel/tire combo, gears, and ratios, it will show you what the top speed is on a per gear basis and in overdrive, for all the ring and pinion combos we offer.
  8. raymond
    raymond Member
    1,283
    2
    Netherlands
    Car:
    FX35 RWD
    That is just where my doubt is. I've been to Frankfurt (Germany) this week and drove for about 4,5 hours on their autobahn. Then you sometime really want/need a higher topspeed. Driving around in a aggresive FX but being blown away by a 2.5 TDI VW Toureag herts i can tell you.But on the other side driving in the netherlands i can hardly drive at topspeed and then you would want more low end action.
    What my main notice was, that the automatic gears shift kinda "Old Skool" you really feel in it schock into another gear sometimes, depening also on the position of your gaspedal at that time.
    Now i've driven with the VW / AUDI DSG system several times and that feels so great,almost F1 like.
    Now i know this won't be able to create on the FX, but will the shifting itself also be any different using the 3.9 Final Gear Drive...?? I mean faster.....harder.....crispy'er....??
  9. Z1Performance
    166
    Smithtown, New York
    it has no affect on the shifting at all in terms of shift feel, etc - that is all in the valvebody
  10. raymond
    raymond Member
    1,283
    2
    Netherlands
    Car:
    FX35 RWD
    Can that be changed as well.....?? And what need to do/buy.....??
  11. Z1Performance
    166
    Smithtown, New York
    sorry we don't offer any such products
  12. Airvtec
    Airvtec Member
    206
    Hayward, CA
    Car:
    2006 FX35
    Couple of tuners offer valve bodies, even torque converters. I have both from GTM. Stillen offers valve body.
  13. raymond
    raymond Member
    1,283
    2
    Netherlands
    Car:
    FX35 RWD
    Okey clear. Thanks for all your help though.Will keep the final gear in mind :top:
    Can you tell me some more about these products and what they do...?? And what your opnion is on them...?? Thanks
  14. Airvtec
    Airvtec Member
    206
    Hayward, CA
    Car:
    2006 FX35
    The valve body upgrade allows the transmission to shift faster, and more crisp. This is pretty noticeable when you go WOT. When driven hard, you can really feel the shifts and the car lurches forward. I can't explain the torque converter as well. Here is a link to read about it http://www.levelten.com/converters.htm :4tongue:
  15. raymond
    raymond Member
    1,283
    2
    Netherlands
    Car:
    FX35 RWD
    Do you have the final gears changed as well...?? And to wich one..? If so what are your experiances together with the valvebody upgrade...??
    Also a collegue of mine did a 350Z today with final gear change. He did this for another collegue and didn't knew for sure wich gear type it was. He thought it was a 3.9
    Driving it the rev-up was substantial faster........maybe even to much for the FX he said and advised to go for a lower gear.
    Any suggestions anyone wich to choise.....not doing any track work..;)
    Rookie you still have the 3.7..?? Why choice this over the 3.9 wich i see offer more true most tuners...
  16. raymond
    raymond Member
    1,283
    2
    Netherlands
    Car:
    FX35 RWD
    Found out today that my collegue has a 4.1 Final Gear in his 350Z and these are very short.
    But understand on the Z1 website that the 3.9 isn't advisable on a automatic transmission.
    But i thought some of you guys had a 3.9 or am i wrong and need to stay with 3.7...??
  17. Z1Performance
    166
    Smithtown, New York
    as posted above:
  18. raymond
    raymond Member
    1,283
    2
    Netherlands
    Car:
    FX35 RWD
    anyone here having a 3.9 Final drive in his FX...?? want to know your opinion...? :wub:
  19. rookie
    2,201
    29
    Westminster OC
    Car:
    car
    Final drive change is the ticket, when more RWD guys try this more will realize.
    Here's G/Z 5AT 3.3 vs FX 3.3 including tire size.
    G35 5AT 3.3 vs FX 3.9 including tire size.
    G35 6MT 3.5 vs FX 3.9 including tire size.
  20. StuLax18
    StuLax18 Staph Moderator
    21,922
    184
    Dallas, TX
    Car:
    2007 FX35 RWD
    What exactly do those graphs mean? Steeper is better, and it shows that you gain speed faster with the 3.3?
