FX35 Experts...I need your help
Discussion in 'FX (03-08) - Engine & Drivetrain' started by LeBron23, Sep 29, 2007.
  1. LeBron23
    LeBron23 Member
    163
    Northridge, CA
    I searched but couldn't find good answer, do you know if 2007 350Z Base open diff. can work for our FX? I have 05 FX35....
  2. rookie
    rookie Premium Member Premium
    2,201
    29
    Westminster OC
    Car:
    car
    The companion flanges are different on the G and Z vs us. The companion flange is the front portion that mates to the driveshaft.
    Examples.
    G/Z
    FX
    Other than that the pumpkin will fit fine. Technosquare has swapped this out for me in the past so they can do it for you if needed. If you get a 6MT pumpkin, the final drive will be changed vs the FX35 RWD.
  3. OP
    LeBron23
    LeBron23 Member
    163
    Northridge, CA
    Oh Thanks Viet!
  4. rookie
    2,201
    29
    Westminster OC
    Car:
    car
    No problem. I think I still have my original pumpkin, but can't remember if we took the companion flange off or not. I'd have to look around in my blackhole of a storage room.
  5. OP
    LeBron23
    LeBron23 Member
    163
    Northridge, CA
    blackhole of a storage room L0L!!!!
    This is the piece I need to replace since mine broke one tooth...I think that's why my car is making that humming noise when foot off the gas pedal and slowly stopping.
    the seller said it's off a 2006 350Z...
  6. rookie
    2,201
    29
    Westminster OC
    Car:
    car
    I found the pumpkin, the companion flange is still in place. It would probably just need fluid to be ready to go.
    That guys picture is of an open differential, and some bearings. Is he trying to troubleshoot some of you problems by saying that will fix it? I'm betting some bearings are bad or are going bad if you're hearing a humming noise while idling down. Bad thing is the costs to replace the bearings is expensive. I just replaced most of my bearings and my final drive since it was damaged (scratch on one of the grooves) parts and labor was near 900 dollars 3 something of that was the final drive ring and pinion.
  7. OP
    LeBron23
    LeBron23 Member
    163
    Northridge, CA
    I thought that's the piece I needed since my open diff. has missing tooth..(I guess one broke out when I blew my tranny? and that's when I started to hear that humming)
    dang...nothingz cheap...$900...but ye humming noise is pretty annoying...I will probably need to take care of that soon.
  8. rookie
    2,201
    29
    Westminster OC
    Car:
    car
    Here's a pic of the pumpkin. I remember Technosquare swapping diff covers since the FX uses a larger gauge bolt. So you'd need to swap diff covers for the install but that's a simple thing to do.
  9. OP
    LeBron23
    LeBron23 Member
    163
    Northridge, CA
    sweet, just let me know when you are available to meet up. :)
  10. OP
    LeBron23
    LeBron23 Member
    163
    Northridge, CA
    Viet! Viet! Viet! I love you man...seriously....after replacing my pumpkin with one that you gave me COMPLETELY made that crazy humming GONE!!!! I'm so glad that I don't hear that loud humming anymore. Thanks alot dude!
