Engine Air Filter Comparison Test
Discussion in 'QX70 Chat' started by Krayzie, Nov 17, 2007.
  1. Krayzie
    Krayzie Aérospatiale
    795
    Vancouver, BC
  2. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Nice article.
  3. Psiclne
    Psiclne Guest
    Very interesting ---
    Who wants to start the GB on the Apexi Power CAI?
  4. FX_Allen
    FX_Allen Member
    640
    California
    o_O interesting
  5. brown_fv
    1,703
    Toronto, On
    Nice read, but remember the test was done on a Supra, and on any other car the results might be entirely different (other than the filtration).
    i think the Apexi had the highest gains because of its open cone filter (suction through the middle as well where it is blocked off on the K&N)
  6. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    I'm looking into this apexi filter to see if there is one that will fit the LMS tube. Will see what research brings out.
  7. Frankiago
    Frankiago Evo Troll Premium
    2,563
    IL
    I agree, there are the K&N X-Stream filters with an open face. K&N filters are less expensive, but the X-Stream version starts becoming just as expensive as the Apex'i
    I'm still stickin with K&N :p
  8. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    1 HP difference is nothing meaningful in the big picture but I do like the no maintenance and no necessary oiling factor of the apexi, not to mention the filtration evidence.
  9. brown_fv
    1,703
    Toronto, On
    I agree 1hp is nothing...but if you are looking for an open face filter you can check out the JWT filter, although you would still have to re-oil it.
    no needed maintenance would be great...
  10. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    But its also the great filtration factor that I am impressed with.
  11. Psiclne
    Psiclne Guest
    Cough *** Throttle body spacer *** cough :rolleyes:
    hahahaha -
  12. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    :LOL::LOL::LOL: Will
  13. BTLFED
    BTLFED Member
    137
    Woodstock GA
    Car:
    2006 FX35 AWD
    From what I read that was also the Twin Turbo Supra, and turbo cars are a bit different from NA cars. Also, Toyota MAF Sensors don't need an oiled filter like the Nissan MAFs do. Even the factory Nissan air filters are oiled. Not using an oiled filter can prematurely burn out the MAF, and they are not cheap to replace.
  14. OP
    Krayzie
    795
    Vancouver, BC
    i was told that Nissan filters shouldnt be oiled and the oil can burn out the MAF...:err:
    EDIT: so theres no more confusion i made a typo...meant to say...
  15. Frankiago
    2,563
    IL
    Paper filters are not supposed to be oiled, they are supposed to be replaced when dirty.
    I'm pretty sure Nissan air filters, like 99% of OEM filters, are paper.
    No MAF sensor requires an oiled filter, while some air filters require oil. That said, ALL MAF sensors require an absence of oil (aka, DON'T GET ANYTHING, INCLUDING OIL, ON THE MAF SENSOR!!!). ;)
    MAF sensors just require cleanliness and to be in the path of the intake air. Get air past the MAF sensor without actually going through the MAF sensor housing and you have what's called a vacuum leak on a naturally aspirated car. This will cause a horrible idle and limp mode from lean conditions.
    Get this same thing on a boosted car and you have what's called a boost leak.
  16. Mongolian
    Mongolian Premium Member Premium
    1,724
    Riverside, CA
    I'd be interested in the Apexi's air filter if we can figure out which universal filter fits our LMS SRI.
  17. Frankiago
    2,563
    IL
    Easy, 3" inlet.
    Anything else our engine bay can handle... it's a huge area there, I picked a random K&N filter that I looked fancy and nice, and stuck it on there. I got an open-faced one with fancy schmancy chrome trim.
    BUT I don't know what will fit inside the Stillen intake box.
  18. john
    john Member
    55
    Wisconsin
    I'm using an apexi on my legacy gt project car. Seems I made the right choice. :)
  19. CO FX
    CO FX Member
    20
    Denver
    The actual filtration part was interesting, especially since I have the HKS mushroom on my WRX. However, 1 whp is just noise on a dyno.
  20. OP
    Krayzie
    795
    Vancouver, BC
    LOL im stupid...i meant that you shouldnt use oiled filters with our MAF:wub:
