Made the switch today after reading about everyone's good experiences with H&R's. I am very pleased so far! My eibach's seemed to sag way too much in the back and bottom out all the time. Now I can actually hit a bump without cringing.
Here are the numbers: Before I went to the shop I took some height measurements. After I got back, I measured again.
Before:
LF: 30 3/4" RF: 30 7/8"
LR: 30 3/4" RR: 30 1/4"
After:
LF: 31 1/8" RF: 31 1/8"
LR: 31 1/8" RR: 31"
The camber was a bit of an adventure. I bought SPC Camber/Toe kits for the G35, and Rookie sent me extended bolts to make the kit work for the FX. For some reason, The bolts in the kit turned out to be the correct size and the custom bolts were way too long. Maybe Rookie's RWD is different?? Maybe cuz I'm an 03? Anyways, the mechanic that was installing the kit was unbelievably slow and he was able to get into spec after modifying only the right rear camber adjuster. He asked if I wanted to do all the bolts, and I just didn't have the time to watch his slow ass labor on it for another 2 hours. So I let it be, and if the springs sag some more and need more adjustment, I can have the rest of the SPC kit installed.
Here are my camber alignment numbers:
LF: -.98 RF: -.76
LR: -1.10 RR: -1.05
Toe:
LF: .06 RF: .06
LR: .09 RR: .11
Eibach and H&R couldn't be more different in design. The Eibach has maybe 3 coils on top and bottom that are wound right on top of each other, and only a small section in the middle can compress. The H&R spring can flex all the way from top to bottom. I would post pics, but I don't know how to upload.
Before:
After:
LR: 31 1/8" RR: 31"
LF: -.98 RF: -.76
LR: -1.10 RR: -1.05
Toe:
LF: .06 RF: .06
LR: .09 RR: .11
