Driving & Track Blog
Discussion in 'FX (03-08) - Boost, Track & Tuning' started by gto, Feb 16, 2015.
  1. gto
    gto Track Ready Moderator
    16,652
    642
    Los Angeles, CA
    Car:
    05 FX35 RWD
    Decided to start a dedicated thread on my track and fun Sundays.
    I'll have a bunch to share this year & going forward.
    First Stop,
    The Thermal Club, Coachella Valley. Sunday Feb 22
    myl168 likes this.
  2. Viperi
    Viperi Premium Member Premium
    2,248
    2
    Toronto, Canada
    Car:
    2008 fx35 AWD
    what car is this? doesn't sound like a fx.
  3. OP
    gto
    16,652
    642
    Los Angeles, CA
    Car:
    05 FX35 RWD
    M4. This is just a random video of the track I'll be at
  4. OP
    gto
    16,652
    642
    Los Angeles, CA
    Car:
    05 FX35 RWD
    Went for 1st alignment. Height is set (for now). Toe was way off. Going to skip camber bolts for now and chose handling over wear. I'm maxed out anyway so I'd need to slot if I want any more positive movement.
    One front BC lower collar came a bit loose, but I figured it would need check after some miles
    ---------- Post added at 12:05 PM ---------- Previous post was at 12:01 PM ----------
    Tire wear front. Road wasnt that dirty, so it may be slightly farther out. I just figured I'd shoot it
    Rear
  5. payyourtoll
    payyourtoll Member
    521
    Tampa
    Name:
    Rob
    That looks great in the back to me. I'm way more off than that. Handling over wear
    My last kooks wore out crazy fast from the camber. My current yokos are like new.
  6. OP
    gto
    16,652
    642
    Los Angeles, CA
    Car:
    05 FX35 RWD
    Well, since you're slammed :)
    I take it you havnt done any slotting.
    Do you know your numbers from last check?
    ---------- Post added at 03:21 PM ---------- Previous post was at 03:19 PM ----------
    That pic above. Just love the rear lip spoiler!
    Thank Admin!!
  7. payyourtoll
    payyourtoll Member
    521
    Tampa
    Name:
    Rob
    I'll have to google what slotting is lol
    I don't remember the numbers but front was near perfect. I probably threw the sheet away while walking out of shop Typical moron. They just cranked the rears as far as it would go of course and I'm thinking the result was 3.5. Your rear looks I don't see many wear issues at all on your ride
  8. OP
    gto
    16,652
    642
    Los Angeles, CA
    Car:
    05 FX35 RWD
    & I can rotate :good:
    Slotting is done to subframe for rear SPC camber kit. Supposed to give you an additional +/- 3.0
    Can U use?
    I also have a rare set of Jefferson bolts that will hold a rear GT Spec bar once the kit is on. Doesnt look like I'll need it. Not low enough
  9. OP
    gto
    16,652
    642
    Los Angeles, CA
    Car:
    05 FX35 RWD
    Gassed and ready
  10. OP
    gto
    16,652
    642
    Los Angeles, CA
    Car:
    05 FX35 RWD
    https://vimeo.com/120390035
    End of day autoX with a full load :/
    ---------- Post added at 11:24 AM ---------- Previous post was at 10:00 AM ----------
    AutoX In evora s
    https://vimeo.com/120398748
    https://vimeo.com/120398953
    ---------- Post added at 11:26 AM ---------- Previous post was at 11:24 AM ----------
    ---------- Post added at 11:33 AM ---------- Previous post was at 11:26 AM ----------
    Really fun day & car did very well. Unfortunately the Gopro kinda failed me on big course & didnt capture, but I think there's some footage of M3 chasing & overtaking me. Might turn up later
    ---------- Post added at 11:40 AM ---------- Previous post was at 11:33 AM ----------
    ---------- Post added at 11:44 AM ---------- Previous post was at 11:40 AM ----------
    https://vimeo.com/120401172
    myl168 likes this.
  11. Ed@TunerStore
    Ed@TunerStore www.tuner-store.com iS VIP
    11,081
    540
    Miami
    Car:
    2004 Infiniti FX35 Supercharged
    Nice pictures Dave
  12. payyourtoll
    payyourtoll Member
    521
    Tampa
    Name:
    Rob
    Gas pump pic
  13. OP
    gto
    16,652
    642
    Los Angeles, CA
    Car:
    05 FX35 RWD
  14. OP
    gto
    16,652
    642
    Los Angeles, CA
    Car:
    05 FX35 RWD
  15. OP
    gto
    16,652
    642
    Los Angeles, CA
    Car:
    05 FX35 RWD
    Big Willow on Thursday :)
  16. Viperi
    2,248
    2
    Toronto, Canada
    Car:
    2008 fx35 AWD
    do you change the tranny fluid often also since you push it ?
  17. OP
    gto
    16,652
    642
    Los Angeles, CA
    Car:
    05 FX35 RWD
    I guess you could look at it that way. I only have 38K on it. I've done one drain & fill, & recently did a complete flush. Forward gears are great . . reverse is taking up to 20+ seconds to engage when it's warm/hot. Cold it goes in without wait. I'm just driving it till it cant go reverse anymore, & then I'll need some sort of fix. Likely reverse piston is failing. I hope it's not a complete rebuild
  18. Viperi
    2,248
    2
    Toronto, Canada
    Car:
    2008 fx35 AWD
    ouch. what brand tranny fluid you use?
  19. OP
    gto
    16,652
    642
    Los Angeles, CA
    Car:
    05 FX35 RWD
    Stock
  20. Viperi
    2,248
    2
    Toronto, Canada
    Car:
    2008 fx35 AWD
    maybe try some other fluid with higher heat resistant like motul ( made for nissans specs)
