FX35 CNR crank Pulley came in!
Discussion in 'FX (03-08) - Engine & Drivetrain' started by jbaker1121, Mar 17, 2008.
  1. jbaker1121
    8,929
    118
    Westchester, New York
    09 FX50
    HEY GUYS
    my CNR crank pulley came in today :wub:
    i bought it new off of a guy on the .org
    i bought the SKF Speedi-sleeve to go with it too:)
    im going to Vinny ten racing on friday to get it installed...hopefully ti all works out :LOL:
    pix: pulley on left...sleeve on right (bottom right..top right is an install tool)
    [​IMG]
    pic of current engine setup......:
    p.s. does anyone reccomend replacing the other pulleys when getting this CNR pulley?
  2. brown_fv
    congrats. you're gonna love the pulley. dont waste your money on the other ones; they cost a lot and they wont help with performance they are just there to look good.
  3. OP
    jbaker1121
    8,929
    118
    09 FX50
    i don't necessarily care about how lit looks under the hood :)
    im really looking forward to getting it installed :)
    question: do you think i need to get a different set of pulleys for the other pulleys to go with the CNR crank pulley? or does it function fine with the stock ones?
  4. brown_fv
    Nope, you just need the one pulley. if the pulley you got is underdriven and not stock sized, you need a smaller belt because the stock one will be too big.
  5. OP
    jbaker1121
    8,929
    118
    09 FX50
    ooo. wait. is it an underdrive pulley?
    here's a side-view pic....
    hopefully i'm okay with stock..my appt. is in 4 days :frown:
    edit: the seller said it was "stock size and all i need is the sleeve for it rto run properly..." so i guess ill be okay :)
  6. fxlr8
    fxlr8 Staff Administrator
    17,961
    770
    California
    None
    I have the cnr lightweight pulley... Make sure when they install the sleeve on the pulley that if the sleeve sticks out past the pulley...they shave it even and smooth.
    also according to the for sale thread it states that it is a stock sized lightweight pulley..so you will not need to purchase any other belts.
  7. gto
    gto Track Ready Moderator
    16,518
    548
    Los Angeles, CA
    05 FX35 RWD
    Uh Oh . . . CNR
  8. OP
    jbaker1121
    8,929
    118
    09 FX50
    don't scare me :eek:
    what's the uh-oh for?
  9. OP
    jbaker1121
    8,929
    118
    09 FX50
    oh yeah thanks for reminding me----:LOL:
    and thanks for pointing that out i appreciate it
  10. gto
    16,518
    548
    Los Angeles, CA
    05 FX35 RWD
  11. fxlr8
    17,961
    770
    California
    None
    man that fxlr8 guy gives some good information in that thread.
    Also it has been over a year since sleeving-shaving the pulley .. I have no leaks whatsoever.
  12. gto
    16,518
    548
    Los Angeles, CA
    05 FX35 RWD
    Yes he does. Wonder why he doesnt post anymore?
  13. OP
    jbaker1121
    8,929
    118
    09 FX50
    i read that entire thread before i actually purchased the pulley/sleeve.
    apparently if you follow the tips that were given: shave down excess sleeve sticking out.....wiggle on the pulley....check for seal folding.....
    then there should be no worries. if there are......
    1. i'll be very upset :mad:
    2. Vinny 10 racing will be fixing it :wub:
    i hope all goes well and it works without any leaks!!!!!!!!!!!!!!!!!!!!
    wish me luck haha
  14. gto
    16,518
    548
    Los Angeles, CA
    05 FX35 RWD
    Good luck then! Is it all worth it though?
  15. OP
    jbaker1121
    8,929
    118
    09 FX50
    i dont know. but i'm a kid, and kids do wild things.
    so i'm gonne see if it works, and if not...then stock goes back on :(
    crazy idea though---i'm going to the stealership tommorow to have them look at mybrakes....should i see if they will install the pulley?
  16. fxlr8
    17,961
    770
    California
    None
    No..
  17. gto
    16,518
    548
    Los Angeles, CA
    05 FX35 RWD
    I wouldnt bother with the dealer. The pulley is a sensitive spot for most dealers, & a possible warranty breaker, cuz if not done right, or part failure, could cause leakage, & if not watched, potentialy cause more problems.
    That all said, enjoy the big horsepower from a pulley :rolleyes:
  18. gto
    16,518
    548
    Los Angeles, CA
    05 FX35 RWD
    Oh by the way . . Go WILD Man!
    & while you're at it, take a jump from the roof into your swimming pool. I think that's what kidz do for fun?
  19. brown_fv
    Nah...dont waste your time. even if they do it their labour rate charges are a lot higher than everywhere else.
  20. OP
    jbaker1121
    8,929
    118
    09 FX50
    so does that mean you guys dont think i shoudl do it?
    i mean only like 4 guys had leakage problems right?
    in the case where you think i should not install the CNR pulley.....
    which pulley do you reccomend...w/prices?
    cuz i mean.....i want the pulley to be installed fo the positives, but the negatives start to outweight the positives :err:
    so......i guess
    unofficial poll:
    install CNR pulley?
    yes... or no...
