FX35 can i disable AWD on my FX 35 04?
Discussion in 'FX (03-08) - Engine & Drivetrain' started by muchilus, Mar 1, 2008.
  1. muchilus
    muchilus Member
    129
    Dominican Republic
    should improve gas mileage? better timing for drag race?
  2. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    No and No. The AWD does not stay on all the time si it doesn't affect gas mileage all that significantly.
  3. brown_fv
    1,703
    Toronto, On
    You can pull the fuse out for the AWD system, but because the weight of the AWD system is there it is not going to make you any faster.
    I was looking into that for the summer when i dont need AWD but its pointless.
  4. OP
    muchilus
    muchilus Member
    129
    Dominican Republic
    thanks,
    but i want to know where is located, because i just saw on the engine fuse comparment the VDC fuse not AWD. can you specify me witch one is ?
    also can you thin pull up the fuse can improve a little in 1/4 mile performance for drag race?
    should be.?
