caliper painting....?
jbaker1121
Im in touch with humanity
iS VIP
Westchester, New York
09 FX50
i saw trainerken's thread about it, but that was mostly about pricing. i was just wondering like what kind of paint should be used, or what i should ask them to use when i go to get them done. some gearheads in my school just spray painted theirs but thats obv. no good. others said powdercoat, others said regular paint.....
guys want to help?
There are special caliper paint that you can use. I have seen it sold at autozone and other automotive shops. Don't know exactly which brand but I know others here have painted their calipers with this special paint.
is it basically like a spraypaint type of thing though? will it still ahev the professional look to it or will it look cheap (im checking onlien for it now btw)
You can do multiple coats and if you take your time it will come out alot better.
And yes any of those should work fine.
Doc is correct you can buy the paint at auto zone, napa, etc and it will say caliper paint. I did mine a while back and only used 2 coats. easy to clean and wash and they still look good. The job is easy, but it does require you to remove your wheels and if you choose your calipers. All kits come with instructions, brush, etc... and will need what ever the time is desire to cure the finish. The results depend on you and your patients.
I highly recommend the G2 caliper paint. They even have, included in the kit, instructions on how to redeem their warranty. They have a LIFETIME warranty against fading, chipping, peeling, cracking, you name it. All you have to do is clean them with a wet rag every so often... I was impressed by that.
Either way, I used G2 and it turned out great.
Man Deecarp! I've never seen these shots before, looks awesome! I wants!!!
sounds like i'm getting the G2 paint then. do you guys think RED will be too tacky? cuz i think it would look sick.
what shoud l i use to clean the calipers before i paint them
how long does a good ol' curing take?
Don't think I ever said hello to you and welcomed you to the Scene.
The G2 caliper Paint comes with a kit that will give you a spray that you can use to clean your calipers. This should only take you about 10 mins. for each Caliper.
Try to apply a rough first and second coat to your calipers and then make the final 3rd coat a day or two after.
Detail is very important no matter what color you use. Make sure to take your time and apply Painters tape to those small areas of the break pads. Dee's came out great.
On you DG fx I suggest you use black and then have them decaled...
Mod on Brother..:wink:
Hmm... How hard would it be to paint the calipers with the calipers still connected to the rotors. Should the calipers be removed? Can you do it without removing the calipers?
Yes, you can paint the callipers without removing the calipper from your disk set up. Like I said, you would have to be very patient and precise when you apply the paint in order for it to look OEM..
thanks humberto!
you did welcome me to the scene..just unofficially lol.
its gonna take me forever to do it becaus ei only have 1 jack, ill have to jack up each wheel at a time.... :(. i think i may just pay the guys at the sHop in town to do it LOL. SOMETIMES IM NOT VERY PATIENT
It looks cheesy as heck if you don't atleast take off the calipers. It makes for a LOT more work, but end result is you don't have that cheesy look with small spatters on the edge of the rotor or on the pads or the pad clips... I had to buy 2 kits and do it on 2 separate days because I took THAT long to do it.
G2 caliper paint has only 4 hours of working time, meaning after 4 hours after mixing the 2 part epoxy-style paint together (paint + hardener/reactor) it's almost unusable and jello-like.
I'll get better pics when I got the 20's on :wink:
this is one of the times i want like a mini-shop in my house. i have none of the tools i need lol. i guess ill be doing yet naothe rtrip to the autoshop in town....
I would just powdercoat and be done with it. Took mine to local shop (LMS), who sent out the calipers to powdercoaters. Turn around time was 2-3 days but the FX was there for other stuff too. Powdercoat cost me $300.00 plus new shims for the calipers and labor to LMS I think was $150.00.
yea your probably right, but
1. i dotn think anyone in my area would charge that little
2. i dont think anyone in my area even does that....but im going to find out
if i cant find anyone near me im just gonna have whoever does my spacers paint them up for me...i went out and picked up the duplicolor kit (only one i can find) for $20, so idk. i hope i can find a place that does powdercoating.
and maybe i can leave my fx at whatever shop i find the same time i'm getting my ecu done...because either way i cant use it for a couple of days...hmmm i gotta think about it.
ill probabyl go wth the powder coat, if i can find aplace
