Braille battery dead again
Discussion in 'QX70 Chat' started by fxlr8, Jun 19, 2007.
  1. fxlr8
    fxlr8 Staff Administrator
    17,984
    779
    Car:
    Other
    My new braille battery has died again, checked it with only 6 volts:eek:.
    I need to get a battery maintainer since I only drive the FX once a week. Plus the mac mini and the alarm probably drained it even more...
  2. Krayzie
    Krayzie AĆ©rospatiale
    795
    Vancouver, BC
    ahh that sucks man, i just realized one of my DTRL is dieing...flashing like crazy :(
  3. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Wow, already? I'm still on my original. Aren't those batteries supposed to last longer and be more durable also?
  4. OP
    fxlr8
    17,984
    779
    Car:
    Other
    Not sure if they are suppose to last longer... If you drive your car everyday or every couple days I am sure they would be fine. If you let your car sit for a bit though you would probably need the maintainer.
    [​IMG]
  5. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    Oh, ok now I see your point.
  6. Deecarp
    Deecarp Member
    1,479
    12
    Bay Area
    Car:
    QX60 AWD
    Name:
    Darryl
    Hey Jeff, try the vector's smart jump and charger, to help maintain your battery. bought one for 81 buck and I have charged 3 batts, and jumped someone car with it already. so it's paid for it self already. Now I don't know much about the Braille battery other than the compact size. have you ever tried the Napa version of the gel cel. I just put in 2 I'm doing a stero install, putting one in the spare tire space. So I hope to have pictures next week. With the upgraded stero and battery version of the gel cel
  7. OP
    fxlr8
    17,984
    779
    Car:
    Other
    I did just buy a charger and maintainer, Wal-Mart special :)
    Whenever I don't plan on driving the car that much I hook it up to the maintainer. I am not really sure if the braille battery is made to handle a cuv.
  8. crayonz
    crayonz Member
    15
    Bay Area
    battery
    new to the site. where's the best place to get a battery charger? i use my fx45 about 2-3 times a week, so just want to get one just in case. thanks, guys!
  9. trainerKEN
    trainerKEN iS VIP iS VIP
    6,174
    4
    Vancouver BC for now
  10. Ripjam
    Ripjam Member
    30
    Baltimore
    This might sound strange but go to a motorcycle dealer to get a battery maintainer they all sell them. Also you might have to check to see if you have a parasitic load causing the battery to drain.
  11. crayonz
    crayonz Member
    15
    Bay Area
    well, my battery is fine. but how would you go about in diagnosing a parasitic load?
  12. Ripjam
    Ripjam Member
    30
    Baltimore
    Use an amp meter in series after you remove the battery cable (neg) you should use a meter that at least support 10amps. The reading after everything powers back up and falls asleep should be a .5 amps or less. There's a stunt you can use in conjunction with the meter that makes it easier to do.
  13. turbocad6
    turbocad6 iS VIP iS VIP
    8,341
    59
    brooklyn, ny
    yeah, it's much safer with a shunt... if you go with a 10 amp meter don't make the mistake of tuning the ign on or anything or you'll blow the fuse in the meter... a shunt can handle 50 amps continuous & can even handle a start as a temporary condition...
  14. Psiclne
    Psiclne Guest
    +1 I have one on my bike now
