Autolumination
Discussion in 'FX (03-08) - Electronics & Lighting' started by Keemo, Mar 12, 2008.
Thread Status:
Not open for further replies.
  1. Keemo
    Keemo Premium Member Premium
    1,108
    Edmonton,AB
    I've been buying a lot of LED's lately from them so I thought I'd post how my experience has been.
    Their lights are very good and I've only had an issue with the 36LED 7440 bulbs that seem to burn out quickley, but I'm using them for my DTRL which could be the reason because they are on so much. Other than that, the lights have worked out really good. I actually replaced the LEDs I got from PIAA, they ended up being two different colours that were double the cost, for my license plate with ones from here. Pic shown with LED license and reverse.
    And here's what the 36LED looks like after about a month. You can see that about a third of it is burnt.
    Dispite the issue with this bulb, their customer service has been great. They replaced the first 36LED for me (I havent tried to replace any more since they all have started to be this short of life in this application) and even switched out the first set of reverse lights at no cost because I didnt like how they looked.
    I plan to go full interior LED with them next. :biggrin:
    http://www.autolumination.com/
  2. Dr.2K
    11,683
    9
    Santa Clarita, CA
    Car:
    2005 FX45
    +1! I have also bought alot of LED's from them and they have been great vendoe to deal with. Also replaced a few of my interior ones as well in the past.
  3. brown_fv
    1,703
    Toronto, On
    My first set of LEDs are still running strong although maybe i should check to see if any are burnt out. i havent noticed a difference in light output so hopefully theyre still fine. prices seem good but shipping to canada tends to take forever.
  4. sgvxcheese
    sgvxcheese Member
    1,123
    Southern California
    Car:
    infiniti fx 35
    hey keemo...which LED's are for the tailights and the license plate light?? im going to buy them now!!!
    Also...what do u recommend i get for my fogs?
    what other lighting did u change
  5. 909FX
    909FX Premium Member Premium
    3,328
    FONTANA, CA
    Car:
    2010 Honda Crosstour
    WWW.VLEDS.COM - I have had no issues with them. They last a long time.
  6. OP
    Keemo
    1,108
    Edmonton,AB
    Yah, it takes like 2 weeks or so for them to come in to Canada which kinda blows but it's not their fault so I didnt want to say any thing.;)
    I got these for my license. 4th one down
    http://autolumination.com/194.htm
    And these for my reverse. First one on the page.
    http://autolumination.com/906.htm
    For my Day Time Running Lights I picked up the 36LED I was talking about. When these ones go out (my third set), I might order the 18 or 24LED and try them.
    http://autolumination.com/7443_7440.htm
    And here's a pic of the 36LED when they're working 100%
  7. jc'sfx
    jc'sfx Premium Member Premium
    1,176
    Joizy
    When I replaced my headlights to the blacked out ones, I saw one of my DTRL's with this issue. I guess it's time to order some more .. *screaming* "honey, can I have some more money so I can buy LED's for pumpkin?" .. :LOL:
  8. mtbfx
    mtbfx Member
    592
    monterey park
    those led's are awesome. any feedback on white interior led's? im curious if the brightness is just right and not too much.
  9. jbaker1121
    8,938
    125
    Westchester, New York
    Car:
    09 FX50
    does nayone know if for the back-up lights you get dual circut or single circut?
    you have the option of 1156 or 1157 for the back-up bulbs and IDK which ones we need....
    and they are the 11 Super-Power Wide Angle High Flux LEDS right?
    also which one exactly is the plate bulb? this:
    194 Superstar Bulbs With Metal Heat Sink
    or
    194 168 W5W 2825 SMT Tower
    i want to make sure i get the right ones :LOL:
    thanks
    so if my cart reads: T10 Wedge
    Item # SMT TowerColor: Super White
    Lens: 194
    $8.99 USD921
    Item # MatrixColor: Super White
    Lens: Wide Angle
    i'm all set for the correct LED setup for the plate and revere, right? jsut double checking.
  10. Frankiago
    Frankiago Evo Troll Premium
    2,563
    IL
    I got eBay LEDs to replace the DTRL's that the dealer stole from me when they swapped out for the tail/headlight recalls :thumpdown:
    The replacement seemed purplish... can anybody give some honest, non-biased feedback on what LEDs are actually white and not blue or purple?
  11. OP
    Keemo
    1,108
    Edmonton,AB
  12. jbaker1121
    8,938
    125
    Car:
    09 FX50
  13. Psiclne
    Psiclne Guest
  14. jbaker1121
    8,938
    125
    Car:
    09 FX50
  15. brown_fv
    1,703
    Toronto, On
    all of them are pretty much the same. ontop of the license plate theres two lights, just unscrew the housing and switch em. just make sure you dont get lights that are too big or else the cover wont fit back on when you need to screw it back in...mine were a really tight fit.
  16. jbaker1121
    8,938
    125
    Car:
    09 FX50
    i bougth the ones ppl said to get haha hopefuly they fit:wub:
  17. jbaker1121
    8,938
    125
    Car:
    09 FX50
    my lights came in...
    one of the reverse lights had half the LED's blown out before i even put it on..AKA it half-worked....
    and KEEMO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! the plate lights dont even fit
    so....guess i need to return the plat eligths, and get a replacement bulb for the reverse..:mad:
    hopefully it's free replacements.
    i'll thorw up pix tm if it even matters.
  18. OP
    Keemo
    1,108
    Edmonton,AB
    the plate ones should've fit if you bought the ones suggested. did you make sure you pushed them in far enough? Sometimes they stick. Use some kleenex so you're not pushing directly on the bulb. and be carefull when you're pushing in the reverse ones, because they are complex little lights, pushing on the bulbs themselves instead of the housing could damage them I'm sure. Autolum will replace one if it's defective but you'll have to email them so they can send you a reply to print and send with the package.
    Good luck!
  19. jbaker1121
    8,938
    125
    Car:
    09 FX50
    thanks. i'll try the license plates ones again...but it seems to be like (|| thats how it fits..... and i hope the LEds werent damaged whil they wer einstalled...oh well. i kept it in anyway cuz i hate having non-matching lights. ill wait for the replacement :)...but yeah
    my day sucked!!!!!!!!!!!!
  20. OP
    Keemo
    1,108
    Edmonton,AB
Thread Status:
