FXchris305
hey guys whats the correct way of changing the antifreeze on the fx35? . i was just gonna drain the radiator and fill it up again with new antifreeze . how would you guys do it ? just asking to make sure . thanks .:err:
http://www.infinitihelp.com/diy/gcoupe/projects/infiniti_g35_coolant_service_procedure.htm
Drain valve is located on the bottom of the radiator.
Air-Relief Valve is located on the passenger side rear radiator hose.
---------- Post added at 07:15 PM ---------- Previous post was at 07:13 PM ----------
Fluid amounts ///137
