FX35 About fuel level problem on fx35?
Discussion in 'FX (03-08) - Engine & Drivetrain' started by muchilus, Feb 7, 2008.
  1. you may be notice if you owned a fx 35, a problem with fuel level sensor , i have change the level units twice, at the beginning start working properly , you full the tank of gas, but after a while, start sending wrong level, like half tank even with the full tank.
    i'm tired of that shit! i want to now if any of yours experience some similar problems and how to fix it.
  2. turbocad6
    turbocad6 iS VIP iS VIP
    8,341
    59
    brooklyn, ny
    I had this problem when I first got mine, but changed the fuel pump & the other sensor & been fine ever since, but only a few months since then too, so??:p
  3. jbaker1121
    8,929
    118
    Westchester, New York
    09 FX50
    you need to bring it to infiniti to change the sensor on the gas-tank side of the wiring, i had the same issue.
  4. bro, i've change the fuel level sensor that is locate in the back seat of the driver side.
    is my second unit.
    to solve this problem i have to change the fuel pump? is not make sense.
    quote=jbaker1121;18855]you need to bring it to infiniti to change the sensor on the gas-tank side of the wiring, i had the same issue.[/quote]
  5. turbocad6
    8,341
    59
    brooklyn, ny
    there are 2 floats, one of them is part of the fuel punp assy, can't get it seperate... good thing is, fuel pump is considered drivetrain, so a decent dealer may be able to cover it under that even if your reg warenty is expired...
  6. Psiclne
    Psiclne Guest
    Dealership replaced both fuel senders on mine and I havent had the problem since.
  7. where is located the second fuel level?
    you say if i change the fuel pump should fix the problem.? taking in mind that already change the fuel level sensor of the gasoline?
  8. jbaker1121
    8,929
    118
    09 FX50
    thats what i meant to say before. haha
  9. so, i'm going to be force to change also the fuel pump, the god damm fuel level is doing the same thing again even with just least of 2 weeks of use.
  10. turbocad6
    8,341
    59
    brooklyn, ny
    the fuel tank is actually kinda like 2 tanks, side by side. there connected in the center of course, but baffles & angle of the vehicle would make a reading from either side inacurate... on such a wide flat tank, a lean to the left & only a float on the left would show way more fuel level than real, same goes for the opposite.
    what it appears infiniti has done is use 2 floats, one on either side, & then averages the readings for a more acurate gauge. so with half a tank, & the fx leaned hard to one side, the side leaned to will show almost full while the side against the lean would show almost empty, averages to half a tank....
    that's why it's hard to know which is faulty, & that's why many will just replace both... only problem is, one of the floats is just a float & one also houses the fuel pump, so one side is $100+ & the other is 300+...
  11. jbaker1121
    8,929
    118
    09 FX50
    really? they did the fixup for free for me :rofl:
  12. yes, you have to buy the fuel pump that incorporate a level sensor two for the rear right side to fix the problem.
  13. Mikefx3508
    Mikefx3508 Guest
    Well when i fill up full tank (93 all the way) it goes down 1/4. Then i start the car again and its on full again. Is that sorta like yur prob?
  14. durak2000
    durak2000 Member
    I've been having the same problem on my '03 for a little under a year now. It was all over the place in higher temperatures but somehow fixed itself when the temps dropped down to 20's-30's.
    I am dumbstruck at this point... I know that if I bring it to my stealership, they'll charge me an arm and a leg just for checking it out. I am out of warranty.
  15. Mikefx3508
    Mikefx3508 Guest
    Also, sometimes i drive around half a mile and i see a significant drop in fuel level. Then it goes back up after a while. What's up with that?
  16. evetr since I've replaced my fuel pump to the Walbro 250, my fule level reads empty about 2-3 galons sooner than empty. The light comes on and I'd drive it a good 20 mile and when I fill it up it filles up to less than 19 galons. Also, the MPG has not been correct. It reads over 25MPG where it should be less than 15.
  17. Frankiago
    Frankiago Evo Troll Premium
    2,563
    IL
    Crap, I have a Walbro 255 going in a couple months from now... I hope I don't have the same issues and hopefully it's not related to the fuel pump.
  18. fxlr8
    fxlr8 Staff Administrator
    17,961
    770
    California
    None
    Should not have problems with the level if you make sure you keep level sensor in the same location/position when changing the pump.
  19. Do you guys know how much it will cost to fix this problem if it's not covered by warranty?
