QX70 09+ 2nd Generation FX Stainless Steel Brake lines 2009+ FX35/FX37/FX50/FX50s Q70 Akebono Calipers
Discussion in 'QX70 Exterior' started by Ed@TunerStore, Jun 7, 2016.
  1. Ed@TunerStore
    Ed@TunerStore www.tuner-store.com iS VIP
    11,099
    542
    Miami
    Car:
    2004 Infiniti FX35 Supercharged
    Hey Folks, I need your help. I've been back and forth with Stoptech all morning trying to find out if the SS brake lines will work on 2009+ FX's with Akebono calipers. They use to offer front and rear, but now only rears are available somehow. I know that they fit the first generation with Akebono calipers for sure, but 2nd generation is a little different and has a hard brake lines to my knowledge or at least the FX50 does.
    My question is, did anyone try to install the Stainless Steel brake lines on 2009+ FX with Akebono Calipers? Thanks in advance!
    illestFX35 likes this.
  2. J3FF3R$0N
    J3FF3R$0N She Needs Premium Dude ! Premium
    4,515
    229
    Milton, Ontario
    Car:
    2004 FX35
    Name:
    Jeff
  3. OP
    Ed@TunerStore
    11,099
    542
    Miami
    Car:
    ^Thanks Jeff. Just want to make sure that the rear Stoptech Brake Lines will work on 2009+ FX35/FX37, before offering them to our customers. Stoptech changed the compatibility this month. I think someone complained that the rear SS lines were too short or something.
  4. J3FF3R$0N
    4,515
    229
    Milton, Ontario
    Car:
    2004 FX35
    Name:
    Jeff
    The 2nd gen rear have hard line on bbk equipped vehicles and the regular brakes are one piece of hose.
    Ill add pics in a minute
  5. J3FF3R$0N
    4,515
    229
    Milton, Ontario
    Car:
    2004 FX35
    Name:
    Jeff
    Ed@TunerStore and illestFX35 like this.
  6. illestFX35
    illestFX35 Member
    761
    213
    Los Angeles/Glendale
    Car:
    2010 FX35 RWD
    this will help A LOOOOOOOTTT. Thanks!
  7. OP
    Ed@TunerStore
    11,099
    542
    Miami
    Car:
    Thank you Jeff!
  8. Kanedean
    Kanedean Premium Member Premium
    335
    34
    Peace River, AB
    Car:
    2013 FX37 AWD
    I have a 2013 FX37 with Akebonos installed. For the rear, I ordered StopTech 950.42500. The line length worked fine, but I had to modify the length of the banjo bolts. They were too long.
    For the front, I ordered StopTech 950.42000, again, I had to modify the length of the banjo bolts.
    Ed@TunerStore likes this.
  9. OP
    Ed@TunerStore
    11,099
    542
    Miami
    Car:
    Thank you!
  10. ocal21
    ocal21 iS VIP iS VIP
    7,903
    297
    Boston, MA
    Car:
    2012 FX35
    Name:
    Oscar
    So will it work with the kit that I am supposed to be getting soon?
  11. ocal21
    7,903
    297
    Boston, MA
    Car:
    2012 FX35
    Name:
    Oscar
    So will it work with the kit i ordered that I should get soon?
  12. Kanedean
    335
    34
    Peace River, AB
    Car:
    2013 FX37 AWD
    I don't quite understand your question.
    If you ordered the above part numbers, they will work, but you will need to shorten the banjo bolts.
    If you ordered from @zebra555, he may have a kit with the short bolts.
  13. OP
    Ed@TunerStore
    11,099
    542
    Miami
    Car:
    Yes, it should work. I'm working on your replacement as we speak.
  14. 6T9CHGR
    6T9CHGR Member
    199
    40
    SINY
    Car:
    2012 FX35 LE
    Name:
    Chris
    I tried using the StopTech 950.42000 front lines in my 2012 FX35 with no luck. No matter which way I positioned it, I could not get it to sit right where I felt comfortable with it not rubbing anything while turning or with suspension travel.
    The factory set up uses 3 separate pieces of rubber line with a section of hard line that runs behind the steering spindle. Its bolted down to a bracket on the spindle as well as another bracket on the strut assy.
    The StopTech line was just a long piece (not long enough to route it the factory way & too long to route it any other way without it rubbing anything. The front line did not come with any p-clamps to secure it any where either. It had one of those nuts that get retained with a clip in the middle of the line....thats it. Maybe thats how the first gen secures the line.....
    I wound up using the factory front line with the Akebonos....
    The rear StopTech lines work perfectly....
  15. forevame
    forevame foreva me
    826
    ny
    Car:
    2009 fx50s
    Bump . What lines do I need for fx50?
  16. forevame
    forevame foreva me
    826
    ny
    Car:
    2009 fx50s
    You
    These lines worked for you ??
