What's New Home Forum Top
Supporter Rides
Register
Welcome to InfinitiScene.com!
Results 1 to 10 of 10
  1. #1
    Join Date
    Jul 2007
    Illinois
    Posts
    6,156
    Ride
    2003 FX45
    Thanks Given
    96
    Thanks Received:
    129
    Wheels / Suspension Deeza, does anyone know this company? (Tie rods)
    Anyone know anything about Deeza (http://www.deezachassis.com/parts_tre.asp)? They make aftermarket tie rod inner and ends for our FX35/FX45. They are about 1/2 the price of OEM, which I believe is made by QSTEN (Part Number: W0133-1628483, Part Number: W0133-1628581).
    My short research is that they make high quality products and there shouldn't be anything to shy me away from saving 50% from OEM.
    Any thoughts?
    http://www.rockauto.com/ (aftermarket)
    DEEZA Part # INT608 More Info {Premium Quality} Patented Stronger Greaseable Version; Front Left Outer $23.79
    DEEZA Part # INT606 More Info {Premium Quality} Patented Stronger Greaseable Version; Front Right Outer $23.79
    Total = $23.79*2 = $10.22 = $57.80
    Premium Quality Patented Design
    New innovative patented design completely eliminates the problems of serviceable chassis parts infiltrating dirt, moisture and other contaminants into the internal cavity of the dust boot.
    Tie Rod Body
    One-piece forged body and CNC machined for perfection.
    Wrench Flats
    For ease of installation, the tie rod body has been designed with wrench flats.
    Dust Boot
    Designed for protecting the joint from contamination. No holes, gaps or valves. Elastic CR 60 material allows the dust boot skirt to bend out only when injected with additional grease.
    Inner Bearing
    Enhanced polymer bearing design resists radial/axial and vibrating forces. POM Material ensures low friction performance during changing operating conditions. Upper steel bearing increases the stud movement. Surfaces are modified by carbonitriding to reduce wear.
    Upper and Lower Rings
    Upper and lower dust boot rings are specifically designed to prevent dust boot tear. Acting much like a spring, they optimally maintain the correct clamping force and remain totally unaffected.
    Ball Stud
    The ball is induction hardened and its surface roughness is decreased into most possible lower level for smooth drive; SAE5140 material is hardened and machined for perfection and zero-defect, and as a result of this process its resistance to corrosion and break away is maximized. Warranty Information
    Deeza 2 year/40,000 mile
    vs infinitipartsusa.com (OEM)
    4) OUTER TIE ROD
    Outer tie rod, fx, right - power - POWER
    03-07 $62.95 $47.21Outer tie rod, fx, left - power - POWER
    03-07 $62.95 $47.21$94.42 + $9.99 = $104.41
    QSTEN
    See More: Deeza, does anyone know this company? (Tie rods)
    Register
  2. #2
    Join Date
    Nov 2008
    NYC
    Posts
    3,025
    Ride
    2005 FX35 AWD
    Thanks Given
    2
    Thanks Received:
    8
    IMO same sh*t different smell..
    if it was my decision ill get them..
  3. #3
    Join Date
    Nov 2009
    Crystal Lake, IL
    Posts
    107
    Ride
    2003 FX35 AWD
    Thanks Given
    9
    Thanks Received:
    5
    I was replacing only the passenger side tie rod end on my FX35 and ordered the IN-T606 part from Rock Auto. When received it was obviously for the other side of the car as it was the mirror image of the part I had removed. I then ordered the IN-T608 part from Amazon and it fit correctly. Even though the parts are referred to as RH and LH, apparently RH and LH do not correspond to Pass and Drivers respectively. In their favor, these parts do have Zerk fittings that the OEM parts do not, but they do not have the drilled hole for a cotter pin. The threads should probably be staked with a chisel for safety. Overall a good value for the price.
  4. #4
    Join Date
    Nov 2009
    Crystal Lake, IL
    Posts
    107
    Ride
    2003 FX35 AWD
    Thanks Given
    9
    Thanks Received:
    5
    Just an update; was greasing the Deeza tie rod ends the other day and found the boot had split open completely top to bottom. Might want to check if you used them. Not too good for a year and a half, maybe 30K. Apparently they have a 2 years/40K warranty, not sure if worth the hassle, since they'll probably want the part in advance of replacement.
  5. #5
    Join Date
    Sep 2011
    Chicago
    Posts
    675
    Ride
    Other
    Thanks Given
    6
    Thanks Received:
    20
    Deeza is a great brand for euro cars. They are treated much like Moog/Spicer.
    But remember there is a budget line and a higher end line for every product. I like them because they normally have grease fittings on their parts.
  6. #6
    Join Date
    Nov 2009
    Crystal Lake, IL
    Posts
    107
    Ride
    2003 FX35 AWD
    Thanks Given
    9
    Thanks Received:
    5
    Maybe there are 2 grades, but not that I can see. I did like the Zerk idea, but also their parts numbers are reversed for US cars and no castle nut/cotter are negs for me. Probably try the warranty route unless they make it too hard. Can send them pix of the split boot. That really should be enough.
  7. #7
    Join Date
    Sep 2011
    Chicago
    Posts
    675
    Ride
    Other
    Thanks Given
    6
    Thanks Received:
    20
    Quote Originally Posted by provels View Post
    I never warrantied suspension parts so I don't know. But maybe u just got a bad one. I've had tie rods from deeza with castle nits and pins. Unless deeza has outsourced more stuff like everyone else.
  8. #8
    Join Date
    Aug 2012
    Tripoli - Libya
    Posts
    327
    Ride
    2004 FX45
    Thanks Given
    17
    Thanks Received:
    17
    I have been running on Deeza tie rods for quite sometime now and nothing bad to report. They are great.
    Sent from my iPad using Tapatalk
  9. #9
    Join Date
    Nov 2009
    Crystal Lake, IL
    Posts
    107
    Ride
    2003 FX35 AWD
    Thanks Given
    9
    Thanks Received:
    5
    Quote Originally Posted by TurTLeG View Post
    Well, they're already from Turkey... Which of course is fine, but I expect they'll demand the part back before they'll replace/refund. Laying up my car for a month while they examine the blown seal on a $20 part will not be an option. Probably just move on to another mfg and not use or recommend them again. What you see in this pic is exactly what you get: http://www.rockauto.com/getimage/get...91-0&width=450 At times, I guess you do get exactly what you pay for....
  10. #10
    Join Date
    Sep 2011
    Chicago
    Posts
    675
    Ride
    Other
    Thanks Given
    6
    Thanks Received:
    20
    Agreed. Spend $20 on another brand and hope for the best.
Similar Threads
  1. Rat Rods #2 Photos
    By BaBaLuwee in forum Chat Scene
    Last Post: 12-17-2010, 08:37 AM
  2. Rat Rods
    Last Post: 07-24-2010, 10:08 PM
  3. Pacific Cookie Company
    By fxlr8 in forum Deals & Reviews
    Last Post: 12-02-2008, 01:19 PM
  4. Nazi Towing Company
    By sgvxcheese in forum Chat Scene
    Last Post: 10-22-2008, 12:12 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
