What's New Home Forum Top
Supporter Rides
Register
Welcome to InfinitiScene.com!
Page 1 of 2 12 LastLast
Results 1 to 20 of 30
  1. #1
    Join Date
    Jul 2008
    Bay Area
    Posts
    15
    Ride
    2003 FX45
    Thanks Given
    Thanks Received:
    MAINT door locks problem (probably not actuators)
    I think I have an issue that will probably stump you guys. So, for the past year Iíve been having problems with the door locks on my Ď03 FX45. They wonít lock/unlock all the time. Iím pretty sure its not an issue with the actuators. Hereís why. During fall/winter the drivers side front and rear locks wonít auto lock/unlock, but the passenger side front and trunk door always work (rear door and gas tank door always works). However, during summer itís the opposite: drivers side front and rear work, but passengers side and trunk donít. Itís definitely not the actuators because it seems that functioning depends on the temperature. Could it have something to do with some electrical connection? Help a little Korean girl out!
    Register
  2. #2
    Join Date
    Jun 2007
    Santa Clarita, CA
    Posts
    10,331
    Ride
    2005 FX45
    Thanks Given
    6
    Thanks Received:
    19
    Well then I think you should change out the actuators on one side and see if that corrects the problem with the change in temperature. If that solves the problem then change the other side. You have a 2003 so it may be time to change them out.
  3. #3
    Join Date
    Feb 2010
    Austintatious, TX
    Posts
    2,940
    Sj
    Ride
    Other
    Thanks Given
    4
    Thanks Received:
    11
    i looked around for this kinda problem but it's the actuator that's mentioned every where, and you're telling us the actuator is not the problem....
    ghosts getting in your car from driver's side during summer and exiting from the passenger side during winter perhaps.
    paranormal activity II
  4. #4
    Join Date
    Dec 2007
    Westchester, New York
    Posts
    7,066
    Ride
    2009 FX50
    Thanks Given
    3
    Thanks Received:
    102
    yeah I have a similar issue: my rear passenger does not lock or unlock from the key fob or from hitting the button on the front doors. However, you can lock and unlock it manually.
  5. #5
    Join Date
    Jul 2007
    Illinois
    Posts
    6,156
    Ride
    2003 FX45
    Thanks Given
    96
    Thanks Received:
    129
    Quote Originally Posted by crayonz View Post
    Not that it matters, but I have a 2003 FX45. You have enough years on your car that it probably is the actuators and my best guess is that it's just random that weather appears to impact it.
    Have you ever changed your battery? If not, you can try that, but I really think it's the actuators. This is a common problem with our FX's.
  6. #6
    Join Date
    Aug 2007
    bay area
    Posts
    38
    Ride
    2004 FX35 RWD
    Thanks Given
    Thanks Received:
    you ever had this issue fixed? my passenger (front door) and rear hatch has the same issue you have.. :frown:
  7. #7
    Join Date
    Nov 2007
    los angeles
    Posts
    2,109
    Ride
    2004 FX35 AWD
    Thanks Given
    Thanks Received:
    lately my passenger door wont unlock with the fob (no problems using the unlock on the door) and wont lock with the fob. its about every other time and a huge pain in the ass because now i have to walk around the car to make sure the doors are locked.
    anyone know how to check an actuator? how much they cost to replace? is it a DIY or a dealer thing? and of course my warranty expired months ago...
  8. #8
    Join Date
    Nov 2007
    brooklyn, ny
    Posts
    6,933
    Ride
    2003 FX35 AWD
    Thanks Given
    12
    Thanks Received:
    103
    the actuators on the fx are built into & are part of the latch/lock assy in each door & you have to replace the whole latch assy, so they are pretty expensive, I think in the $200+ neighborhood each for just the part. to make matters worse, all the actuators have pretty much about the same amount of wear as the others, so what I see is that usually shortly after the first one gets replaced another one goes...
    the reason why it may work with the switch & not the fob is probably because it is weak, from the fob the locks only gt a short pulse of a few 100 ms duration, where if you use the switch you are able to lengthen the amount of time the lock actuator has to do it's thing...
  9. #9
    Join Date
    Nov 2007
    los angeles
    Posts
    2,109
    Ride
    2004 FX35 AWD
    Thanks Given
    Thanks Received:
    any idea on level of experience needed to switch one out? for regular humans... not you john
  10. #10
    Join Date
    Nov 2007
    brooklyn, ny
    Posts
    6,933
    Ride
    2003 FX35 AWD
    Thanks Given
    12
    Thanks Received:
    103
    Its not hard, remove the door panel, remove the 3 torx screws holding the latch in the door jamb, then disconnect the cables that attach to both the inner & outer handles & stuff & the electrical plug that's for the actuator, remove the latch assy, then re install... havent done one recently enough to remember all the little details about whats involved in disconnecting & re installing the cables but should be pretty straight foward, do you have the fsm pdf? I think you may need to remove the window glass & the regulator for access, also not hard... but then again easy/hard is relative I guess, having the new latch in your hand as you 're doing it helps too cause you can look at the new one to help figure it out.
    Sent from my droid using Tapatalk
  11. #11
    Join Date
    Aug 2008
    Hesperia, CA
    Posts
    2,742
    Ride
    2004 FX35 RWD
    Thanks Given
    21
    Thanks Received:
    92
    Ash, not really too hard...did my rear and front passenger doors in about 1.5 hours. And that was going in and out of the house looking at the post that shows how to do it...no laptop for me....I could do it now in about 20-30 minutes for the front door and about 15-20 minutes now for the rear door.
  12. #12
    Join Date
    Nov 2007
    los angeles
    Posts
    2,109
    Ride
    2004 FX35 AWD
    Thanks Given
    Thanks Received:
    thank you gentlemen! looks like i got a weekend project coming up.
    actuators.... buy them new from dealer? store like NAPA? prolly not the best idea from a junkyard or something right?
  13. #13
    Join Date
    Nov 2007
    brooklyn, ny
    Posts
    6,933
    Ride
    2003 FX35 AWD
    Thanks Given
    12
    Thanks Received:
    103
    dealer item, probably best price from a place like infinitipartsusa or something, not gonna find it in an auto parts store... used would be tough too cause even if you did find a yard with an fx, most likely there going to want to sell the door complete, then theres the risk factor of not knowing how long a used one's gonna last either. guess if you got lucky & found a good used one cheap then maybe, but that's gotta be hard to find I think...
  14. #14
    Join Date
    Dec 2009
    California
    Posts
    47
    Ride
    2005 FX35 AWD
    Thanks Given
    Thanks Received:
    have exact same problem then i brought to the dealer (INFINITI MONROVIA)
    and they fix it their really good.
  15. #15
    Join Date
    Aug 2008
    Hesperia, CA
    Posts
    2,742
    Ride
    2004 FX35 RWD
    Thanks Given
    21
    Thanks Received:
    92
    Quote Originally Posted by asherchy View Post
    Dealer item ONLY. Try Riverside Infiniti. They have really good prices on everything. I bought both of my actuators there for $380 talk to Tony from Internet Sales.
  16. #16
    Join Date
    Nov 2007
    brooklyn, ny
    Posts
    6,933
    Ride
    2003 FX35 AWD
    Thanks Given
    12
    Thanks Received:
    103
    that's def a good price, I got a dead one on my right front door for a while now, but keep thinking that it in the end it might be cheaper & better to just retrofit all the doors with aftermarket actuators instead. never got a chance to look at much there, would be a bit of a project though
  17. #17
    Join Date
    Jul 2009
    Chicagoland
    Posts
    4,532
    Ride
    2007 FX45
    Thanks Given
    29
    Thanks Received:
    118
    Looks like two of my actuators are going out now too. It's completely random when it works, but on the same two doors at the least. It sometimes unlocks with the keyfob or not. And using the actual switch on the door is random too. Seems like there is some resistance in the part for the lock to work. This sucks because I can't imagine how many time my car has been unlocked over the past few weeks. Is it recommended just to change all four at once by now? Is this part covered under extended warranty or do I have an incoming DIY....
  18. #18
    Join Date
    Jul 2007
    Illinois
    Posts
    6,156
    Ride
    2003 FX45
    Thanks Given
    96
    Thanks Received:
    129
    Quote Originally Posted by AeroBFA View Post
    Looks like two of my actuators are going out now too. It's completely random when it works, but on the same two doors at the least. It sometimes unlocks with the keyfob or not. And using the actual switch on the door is random too. Seems like there is some resistance in the part for the lock to work. This sucks because I can't imagine how many time my car has been unlocked over the past few weeks. Is it recommended just to change all four at once by now? Incoming DIY....
    Just change it when they fail. After 120k+ miles, my drivers side has failed at around 100k.
    Now at 120k, my passenger front door is failing (opens sometimes, sometimes not). Parts.com has the cheapest actuators. Or you can try the $5 mod, which your buddy handy andy should be able to do with his eyes closed now he has taken apart his tranny...
  19. #19
    Join Date
    Jul 2009
    Chicagoland
    Posts
    4,532
    Ride
    2007 FX45
    Thanks Given
    29
    Thanks Received:
    118
    Ya, I think I would rather do the $5 fix than taking the car to the dealer and risk my wheels getting scratched etc. Thanks for the parts.com reference, I'll check it out. Haha, Andrew needs to change his tag to Handy_Andy :rofl:
  20. #20
    Join Date
    Jul 2007
    Illinois
    Posts
    6,156
    Ride
    2003 FX45
    Thanks Given
    96
    Thanks Received:
    129
    $165 for the actuator about each. Replaces entire assembly. Install for Handy_Andy will be 30 minute each door.
    $5 for universal actuator and you have to do some minor adjusting/modifications.
Similar Threads
  1. [FX35 09-12] Door locks ???
    By timlmistretta in forum FX (09+) - Interior & Exterior
    Last Post: 04-22-2012, 02:25 PM
  2. [FX35 03-08] door lock problem
    By fx35_UCH in forum FX (03-08) - Interior & Exterior
    Last Post: 09-05-2010, 04:19 AM
  3. Interesting Hatch Door Problem
    By sake_yo in forum FX (03-08) - Electronics & Lighting
    Last Post: 03-22-2010, 11:23 AM
  4. Wheel Locks
    By theMerchant in forum FX (03-08) - Wheels & Suspension
    Last Post: 10-21-2008, 08:36 AM
  5. Reverse Camera & auto door locks
    By mrpanther in forum FX (03-08) - Electronics & Lighting
    Last Post: 09-07-2008, 09:56 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
