What's New Home Forum Top
Supporter Rides
Register
Welcome to InfinitiScene.com!
Results 1 to 6 of 6
  1. #1
    Join Date
    Jan 2010
    San Diego
    Posts
    75
    Ride
    2003 FX35 RWD
    Thanks Given
    Thanks Received:
    MAINT Power steering pump noise???
    Ok so recently i started hearing a "humming" or "hissing" type sound coming from the steering column/engine bay at idle when it is quiet. when i slightly turn the wheel and put the power steering under load, it stops. i thought it was coming from the steering column at first, but upon further inspection it seems like it is coming from the pump and maybe the noise is just getting transmitted to the steering area. i had the power steering fluid totally flushed with no change. the mechanic said my pump might be starting to go bad. he said there was a "very slight" wobble in the pully and those are pressed, so eventually ill have to get it replaced when it does go bad. anyone had experience with this? thanks!
    See More: Power steering pump noise???
    Register
  2. #2
    Join Date
    Apr 2008
    Big Bear City,Ca.
    Posts
    4,257
    John Green
    Ride
    2004 FX35 AWD
    Thanks Given
    96
    Thanks Received:
    105
    Possibly air in system--
    Air Bleeding Hydraulic System
    AGS000GV
    Incomplete air bleeding causes the following. When this happens, bleed air again.
    Generation of air bubbles in reservoir tank.
    Generation of clicking noise in oil pump.
    Excessive buzzing in oil pump.
    NOTE:
    When vehicle is stationary or while steering wheel is being turned slowly, some noise may be heard from
    oil pump or gear. This noise is normal and does not affect any system.
    1. Stop engine, and then turn steering wheel fully to right and left several times.
    CAUTION:
    Do not allow steering fluid reservoir tank to go below the low-level line. Check tank frequently and
    add fluid as needed.
    2. Run engine at idle speed. Turn steering wheel fully to the right and then fully to the left, and keep for about
    three seconds. Then check whether a fluid leakage has occurred.
    3. Repeat the 2nd procedure several times at about three seconds intervals.
    CAUTION:
    Do not hold steering wheel in the locked position more than 10 seconds. (There is the possibility
    that oil pump may be damaged.)
    4. Check generation of air bubbles and cloud in fluid.
    5. If air bubbles and the cloud don't fade, stop engine, hold air bleeding until air bubbles and the cloud fade.
    Perform the 2nd and the 3rd procedures again.
    6. Stop engine, check fluid level.
  3.    The Following User Says Thank You to MTN FX For This Useful Post:
  4. #3
    Join Date
    Jan 2010
    San Diego
    Posts
    75
    Ride
    2003 FX35 RWD
    Thanks Given
    Thanks Received:
    MTN FX you are the man! i had people (mechanics) telling me that the pump might be going bad, the valve is bad...etc. all i did was go full left to right 5 times, and the noise is gone! thanks alot for your input and for possibly saving me lots of time and money!!
  5. #4
    Join Date
    Mar 2008
    Southern California
    Posts
    5,928
    Ride
    2005 FX35 RWD
    Thanks Given
    50
    Thanks Received:
    11
    nice and good to know :tup: :tup:
  6. #5
    Join Date
    Apr 2008
    Big Bear City,Ca.
    Posts
    4,257
    John Green
    Ride
    2004 FX35 AWD
    Thanks Given
    96
    Thanks Received:
    105
    Quote Originally Posted by SanDiegoMarine View Post
    Cool glad it worked out for you. Iv'e come to realize that allot of so called mechanics even at dealerships out there are only guessing half the time that's why it's so important to find a good mechanic you can trust!
    PS: and thanks for your service!!!
  7. #6
    Join Date
    Apr 2010
    Inland Empire, CA
    Posts
    3,724
    Ride
    2003 FX45
    Thanks Given
    55
    Thanks Received:
    151
    How sensitive are we to the type of power steering fluid to use?
    The filler cap says "USE DEXRON TYPE ATF"
    The manual says "Use Genuine Nissan PSF or equivalent"
    Is any regular ole power steering fluid okay for a top off?
Similar Threads
  1. [FX35 03-08] Power Steering Pump replacement
    By rhythmnsmoke in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 02-28-2015, 12:37 AM
  2. No Power Steering
    By david in forum FX (03-08) - Wheels & Suspension
    Last Post: 01-28-2015, 12:49 PM
  3. [FX GEN1] Power Steering Fluid Swap (Using Fluid Transfer Pump)
    By fxlr8 in forum FX (03-08) - Write-Ups
    Last Post: 10-12-2014, 07:25 PM
  4. [FX35 03-08] Leaking Power Steering Pump
    By david in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 02-03-2013, 03:51 PM
  5. [FX35 03-08] walbro fuel pump noise??
    By sch4400 in forum FX (09+) - FX35 Engine & Drivetrain
    Last Post: 12-18-2009, 12:19 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
