What's New Home Forum Top
Supporter Rides
Register
Welcome to InfinitiScene.com!
Results 1 to 12 of 12
  1. #1
    Join Date
    Dec 2008
    va fairfax
    Posts
    24
    Ride
    2006 FX35 AWD
    Thanks Given
    Thanks Received:
    DIY Quick fog light Question!
    Hi all~
    My fx just gone left side fog light so i bought h8 light bulb.
    But it's frist time to change the fog light. Do i have to take off the bottom plastic??
    See More: Quick fog light Question!
    Register
  2. #2
    Join Date
    Jun 2007
    South Gate, CA
    Posts
    4,842
    Ride
    2004 FX45
    Thanks Given
    17
    Thanks Received:
    12
    Yes.
    You will have to take off the bottom plastic. Then get down there and remove the Bulb..
    BTW are you sure you got the right bulb?
  3. #3
    Join Date
    Dec 2009
    Fairfax, VA
    Posts
    193
    Ride
    2006 FX35 AWD
    Thanks Given
    8
    Thanks Received:
    2
    I'm not sure if I'm allowed to post a link to the org but someone there did a DIY on replacing the fog light.
    http://www.infinitifx.org/viewtopic.php?f=62&t=18804
    (Moderator please delete my reply if I'm not supposed to post a link to the org)
  4. #4
    Join Date
    Dec 2007
    Westchester, New York
    Posts
    7,003
    Ride
    2009 FX50
    Thanks Given
    3
    Thanks Received:
    95
    yeah there you go you dont have to take off the bottom for just the bulb, but if you have to replace the lens or play with HID ballasts like I do, you have to take off the bottom and it sucks
  5. #5
    Join Date
    Apr 2008
    Dallas, TX
    Posts
    17,801
    Ride
    2007 FX35 RWD
    Thanks Given
    48
    Thanks Received:
    198
    H8 is the correct bulb. And taking off the plastic isn't that bad, well at least for me because I'm missing half of those stupid bolts.
  6. #6
    Join Date
    Dec 2007
    NYC
    Posts
    5,608
    Ride
    Other
    Thanks Given
    96
    Thanks Received:
    101
    i suggest the 'org' way that ejay posted if its warm weather as it is easier. I replaced my fogs today (trying to climb a mountain of snow in a parking lot was a BAD idea) and could not use the org way as it was freezing, the plastic would not move out of the way as it was not as bendable. Not sure if weather was an issue but ive done this a million times before in the summer and the plastic was easily pushed out of the way. The method of removing the plastic on the bottom of the card is much more annoying, imo, but had to resort to that today
  7. #7
    Join Date
    Dec 2007
    Posts
    7,003
    Ride
    2009 FX50
    Thanks Given
    3
    Thanks Received:
    95
    Quote Originally Posted by pmanliu View Post
    i suggest the 'org' way that ejay posted if its warm weather as it is easier. I replaced my fogs today (trying to climb a mountain of snow in a parking lot was a bad idea) and could not use the org way as it was freezing, the plastic would not move out of the way as it was not as bendable. Not sure if weather was an issue but ive done this a million times before in the summer and the plastic was easily pushed out of the way. The method of removing the plastic on the bottom of the card is much more annoying, imo, but had to resort to that today
    the bulbs or the lens? What did you replace? I need to replace one of my lens so i was wondering if i had to take the bumper off or not...
  8. #8
    Join Date
    Dec 2007
    NYC
    Posts
    5,608
    Ride
    Other
    Thanks Given
    96
    Thanks Received:
    101
    Quote Originally Posted by jbaker1121 View Post
    i replaced the bulbs, not the lens. If you replace the lens im pretty sure your bumper has to be removed
  9. #9
    Join Date
    Nov 2008
    Boston
    Posts
    119
    Ride
    2003 FX35 AWD
    Thanks Given
    Thanks Received:
    Nothing has to be removed at all!!!
    There are two soft plastic covers on both sides (you can feel it with your hands), just move those away and you have full access to your fogs. I changed 2 fog light modules without removing anything at all. You just need a lot of patience and flexible wrists (you kinda work blindly). Look at the assembly, visualize it in your head and get going.
    It took me all of the 20 minutes to change and adjust 2 of my cracked fogs.
    Here's the instrauctions:
    1. push the plastic cover away
    2. the fog light is held in the panel socket by the 10mm bolt on the top (reach in to feel it)
    3. go in from the top with a 10mm socket, unscrew the top bolt
    4. pop out the fog light from the 2 bottom clips and disconnect the wire
    5. clean the socket from the inside
    6. install a new one
    7. poor yourself 4 beers into a big mug, chug it down and pat yourself on the back :)
  10. #10
    Join Date
    Dec 2008
    va fairfax
    Posts
    24
    Ride
    2006 FX35 AWD
    Thanks Given
    Thanks Received:
    Thank u all~~~!!
  11. #11
    Join Date
    Dec 2007
    Posts
    7,003
    Ride
    2009 FX50
    Thanks Given
    3
    Thanks Received:
    95
    Quote Originally Posted by durak2000 View Post
    so you from underneath and take those plastic covers off, correct? I'm down there all the time to play with my HIDs
  12. #12
    Join Date
    Nov 2008
    Boston
    Posts
    119
    Ride
    2003 FX35 AWD
    Thanks Given
    Thanks Received:
    no, I don't think you have to take any plastic covers from underneath off.
    The soft plastic covers I am talking about can be located by:
    -face the vehicle
    -put your wrist through the air vent (gap,opening, whatever you want to call it).
    -these plastic covers are located to the right and left of the fogs (on the sides), just press them in a bit, get a grip and easily pull it in or out (NOT FULLY, just enough to give yourself some room to work).
    - get in there with a 10mm sockets and get it done! :)
    while you CAN work from underneath to change a bulb or whatevs, I found it REALLy uncomfortable, even impossible to take the fog assembly out completely.
    That's it!
Similar Threads
  1. [FX45 03-08] Quick question..
    By JST4FN in forum FX (03-08) - Electronics & Lighting
    Last Post: 11-11-2010, 04:33 AM
  2. Quick fog question
    By solekeeper in forum FX (03-08) - Electronics & Lighting
    Last Post: 05-20-2009, 07:49 PM
  3. Quick Question about brakes..
    By solekeeper in forum FX (03-08) - Wheels & Suspension
    Last Post: 10-14-2008, 07:07 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
