What's New Home Forum Top
Supporter Rides
Register
Welcome to InfinitiScene.com!
Results 1 to 7 of 7
  1. #1
    Join Date
    Nov 2008
    NYC
    Posts
    3,025
    Ride
    2005 FX35 AWD
    Thanks Given
    2
    Thanks Received:
    8
    MAINT Check engine codes
    Hi my friend FX recently came up with the check engine light on the code is P0507.
    Does anyone know what this code refer to?
    I used the search bar and didn't find anything so I hope we can use this thread to incorporate codes and the description of it.
    Thanks
    See More: Check engine codes
    Register
  2. #2
    Join Date
    Dec 2007
    Westchester, New York
    Posts
    7,066
    Ride
    2009 FX50
    Thanks Given
    3
    Thanks Received:
    102
    P0507
    0507
    Idle speed control system RPM higher than expected
    The idle speed is more than the target idle speed by 200 rpm or more.
    sounds likes it could simply be a dirty throttle body. to the dealer!
    "DTC P0507 ISC SYSTEM PFP:23781
    Description EBS00C2G
    NOTE:
    If DTC P0507 is displayed with other DTC, first perform the trouble diagnosis for the other DTC.
    The ECM controls the engine idle speed to a specified level through the fine adjustment of the air, which is let
    into the intake manifold, by operating the electric throttle control actuator. The operating of the throttle valve is
    varied to allow for optimum control of the engine idling speed. The crankshaft position sensor (POS) detects
    the actual engine speed and sends a signal to the ECM.
    The ECM controls the electric throttle control actuator so that the engine speed coincides with the target value
    memorized in the ECM. The target engine speed is the lowest speed at which the engine can operate steadily.
    The optimum value stored in the ECM is determined by taking into consideration various engine conditions,
    such as during warming up, deceleration, and engine load (air conditioner, power steering and cooling fan
    operation, etc.).
    On Board Diagnosis Logic EBS00C2H
    DTC Confirmation Procedure EBS00C2J
    NOTE:
    l If “DTC Confirmation Procedure” has been previously conducted, always turn ignition switch “OFF” and
    wait at least 10 seconds before conducting the next test.
    l If the target idle speed is out of the specified value, perform “Idle Air Volume Learning”, EC-677 ,
    before conducting “DTC Confirmation Procedure”. For the target idle speed, refer to the “Service
    Data and Specifications (SDS)”, EC-1301 .
    TESTING CONDITION:
    l Before performing the following procedure, confirm that battery voltage is more than 11V at idle.
    l Always perform the test at a temperature above -10C (14F).
    WITH CONSULT-II
    1. Open engine hood.
    2. Start engine and warm it up to normal operating temperature.
    3. Turn ignition switch “OFF” and wait at least 10 seconds.
    4. Turn ignition switch “ON” again and select “DATA MONITOR”
    mode with CONSULT-II.
    5. Start engine and run it for at least 1 minute at idle speed.
    6. If 1st trip DTC is detected, go to EC-1036, "Diagnostic Procedure"
    WITH GST
    Follow the procedure “WITH CONSULT-II” above.
    DTC No. Trouble diagnosis name DTC detecting condition Possible cause
    P0507
    0507
    RPM higher than
    expected
    l Electric throttle control actuator
    l Intake air leak
    l PCV system"
  3. #3
    Join Date
    Jun 2007
    California
    Posts
    12,181
    Ride
    Other
    Thanks Given
    310
    Thanks Received:
    401
  4. #4
    Join Date
    Dec 2007
    Posts
    7,066
    Ride
    2009 FX50
    Thanks Given
    3
    Thanks Received:
    102
    ^there you go.
    /thread
  5. #5
    Join Date
    Nov 2008
    NYC
    Posts
    3,025
    Ride
    2005 FX35 AWD
    Thanks Given
    2
    Thanks Received:
    8
    Cool thanks guys!! I'll will post a few codes #'s and descriptions I have too. Thank you once again guys.
  6. #6
    Join Date
    Dec 2007
    Posts
    7,066
    Ride
    2009 FX50
    Thanks Given
    3
    Thanks Received:
    102
    Quote Originally Posted by Rubare View Post
    no doubt yo. :tup:
  7. #7
    Join Date
    Nov 2008
    NYC
    Posts
    3,025
    Ride
    2005 FX35 AWD
    Thanks Given
    2
    Thanks Received:
    8
    this is a website I like to look at they have great articles on how to fix and manage some codes.
    http://www.engine-light-help.com/che...t-testing.html
    P1105 MAP/BARO Switch Solenoid Valve
    P1110 Intake Valve Timing Control (Left Bank)
    P1120 Secondary Throttle Position Sensor (STPS)
    P1125 TPS Intermittent
    P1130 Swirl Control Valve Control Solenoid Valve
    P1135 Intake Valve Timing Control (Right Bank)
    P1140 Intake Valve Timing Control Position Sensor (Left Bank)
    P1145 Intake Valve Timing Control Position Sensor (Right Bank)
    P1148 Closed Loop Control (Bank 1)
    P1165 Swirl Control Valve Control Vacuum Check Switch
    P1168 Closed Loop Control (Bank 2)
    P1210 Traction Control System (TCS)
    P1220 Fuel Pump Control Module (FPCM)
    P1320 Ignition Signal, Primary - Related Information
    P1335 Crankshaft Position Sensor (CKPS) (Ref)
    P1336 Crankshaft Position Sensor (CKPS) (Cog)
    P1400 EGRC Solenoid Valve - Read Our Article On EGR Valve Codes For Help With This Infiniti Check Engine Light Code
    P1401 EGR Temperature Sensor - Read Our Article On EGR Valve Codes For Help With This Infiniti Check Engine Light Code
    P1402 EGR Function (Open) - Read Our Article On EGR Valve Codes For Help With This Infiniti Check Engine Light Code
    P1440 EVAP Control System (Small Leak) (Positive Pressure)
    P1441 VC/V Bypass Valve
    P1443 Canister Control Vacuum Check Switch
    P1444 Canister Purge Volume Control Solenoid Valve
    P1445 Purge Volume Control/V
    P1446 EVAP Canister Vent Control Valve (Close)
    P1447 EVAP Control System Purge Flow Monitoring
    P1448 EVAP Canister Vent Control Valve (Open)
    P1490 Vacuum Cut Valve Bypass Valve (Circuit)
    P1491 Vacuum Cut Valve Bypass Valve
    P1492 EVAP Canister Purge Control/Solenoid Valve (Circuit)
    P1493 EVAP Canister Purge Control Valve/Solenoid Valve
    P1605 A/T Diagnosis Communication Line
    P1705 Throttle Position Sensor
    P1706 PNP Switch
    P1760 Overrun Clutch Solenoid Valve
    P1900 Cooling Fan
Similar Threads
  1. Help!!!!! check engine light,slip,vdc off
    By spersad11417 in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 12-28-2012, 02:38 PM
  2. [FX35 03-08] Check Engine Light + VDC OFF
    By DodgeDanger in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 08-24-2009, 03:41 PM
  3. [FX45 03-08] Obd codes help
    By loteee in forum FX (03-08) - FX45 Engine & Drivetrain
    Last Post: 03-25-2009, 08:29 PM
  4. Most Expensive Zip Codes
    By StuLax18 in forum Chat Scene
    Last Post: 10-21-2008, 11:25 PM
  5. HP codes coupons
    By fxlr8 in forum Deals & Ebay Links
    Last Post: 07-19-2008, 06:17 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
