What's New Home Forum Top
Supporter Rides
Register
Welcome to InfinitiScene.com!
Results 1 to 14 of 14
  1. #1
    Join Date
    Nov 2007
    brooklyn, ny
    Posts
    6,933
    Ride
    2003 FX35 AWD
    Thanks Given
    12
    Thanks Received:
    103
    Wheels / Suspension HOW TO: drill aftermarket rims for tpms
    ok, had to do this last week for my IForged wheels... it's pretty simple but I took a few shots to be able to give a quick guide to doing this... the biggest problem or fear for most is that they'll drill a hole & then it won't work, thereby ruining there rim. well, if you follow the procedures I used you won't have to worry all that much, as it's the best way to properly locate & drill this one simple, but oh so intimidating hole...
    many aftermarket rims, especially 3 piece wheels & rims with wide lips, will usually load the tire from the back of the wheel instead of the front like the OEM wheels. this will mean that the recessed channel that creates a step in the lip will be in the back of the wheel instead of the front. this recessed step is usually where the tire valve is located, but since the recessed lip is in the back of these aftermarket rims, they usually use some other sort of way to allow a tire valve to be used & accessed from the front. usually it's some sort of proprietary design & accesses the air fill from somewhere in the center of the rim & this valve fill location is usually unusable for the tpms sensor, as it's designed to sit in the stepped lip area that is now on the back of the wheel.
    in many cases it can be as simple as just drilling your own valve stem hole in the correct spot on the rear stepped lip & walla, instant tpms compatibility. it is up to you to determine if your lip looks suitable for this, & not all will always be on exactly the right angle, but even a little off the tpms can still be mounted... these pictures are from my fronts & the tpms fits perfectly, but the rear lips were a little different & the tpms sat a bit off the rim, still works fine though & is still protected somewhat in case of a flat, but it is always ideal that they sit like shown in these pictures, all the way up into the channel...
    __________________________________________________ _________________
    tools needed:
    first step, once you sure that the tpms will sit in the rim is to determine exactly where to drill the hole. if you drill it in the wrong spot then not only will the sensor not sit right in the wheel, but it is possible it won't even seal... if you drill on the edge of a flat or off on a curve then the sensor will not seal... the sensor needs to sit on a relatively flat area to seal properly.... the correct spot for this hole is very critical, you shouldn't just eyeball it or wing it, the best way to properly find the exact spot is to use the tpms tightening nut/collar to locate a flat area for it to sit on
    place the collar on the flat part of the step, determine a spot that it can sit flat, this is where you want it to sit on final tightening. use the 23/64th's bit to locate the precise center of this spot. the sensor should be located directly opposite the factory valve stem for balancing, actually counterbalancing against the original valve... if you placed it at the same spot on the rim as the other fill valve you will be creating a heavy area that will need much wheel weights to make up for, always space them 180% opposite each other...
    the bit will fit in the collar snug enough to be perfectly straight & centered, but not tight enough that you can't spin the bit... it'll glide on the inner surfaces of the collar nut & not damage it at all... use this bit to drill into the wheel just enough to give you the center point. you don't want to go all the way through with this bit, drill enough to get a good point
    & then remove the bit & switch it out for a small bit. use the small bit to drill your pilot hole. 1/8th" is good, little bigger or smaller is also ok, nothing 1/4" or larger though. a small bit will go through straight & not walk... run the bit through the center of the collar nut,
    use the collar nut as a guide to drill straight & at the same angle as the nut will sit on the flat part of the step... drill straight through
    now the pilot hole will make drilling the large hole easy... the large bit will always follow the pilot hole(hence the reason it's called a pilot hole) & be in the precise spot it needs to be. you cannot drill through the center of the collar nut with your last bit, cause the final hole is larger than the center of the collar nut, but you should still hold the collar nut right along side the hole you will be drilling, still using it as a guide to your angle & straightness relative to how the collar sits on the rim
    the final bit I use is 7/16... this is the size of the final hole for all normal car valve stems... actually 7/16th's is a little tight, I rather run the drill through a few times to clean it up till it fits snug than stare at a hole that's too loose. after running it through with the 7/16, clean up & debur the inner side of the hole, as it's the sealing surface for the sensor.
    try to wiggle the sensor in, if it goes in great, if not, run the bit through the hole a few times & try again... it won't need much... once the sensor is in, tighten till the seal bulges, you don't need to necessarily crank them till they bottom, just tighten them till you have nice rubber compression & it's good to go...
    of course you could just ignore all of this, just chuck up a 7/16'th bit & wing it, eyeball it straight & centered & bang, poke the hole... I've done that before but this method is def the safest way to get it right & worth the trouble... a pilot hole is always a good idea for any large hole drilling & helps the large bit go through like butter rather than burning out & walking all over the place..
    Register
  2. #2
    Join Date
    Nov 2007
    brooklyn, ny
    Posts
    6,933
    Ride
    2003 FX35 AWD
    Thanks Given
    12
    Thanks Received:
    103
  3. #3
    Join Date
    Jun 2007
    Santa Clarita, CA
    Posts
    10,331
    Ride
    2005 FX45
    Thanks Given
    6
    Thanks Received:
    19
    Nice write-up John. iforged had already done similar for me with my wheels and it has worked out very well. I actually have 2 holes, one for the air valve stem on the outer side and one on the inner side for the tpms.
  4. #4
    Join Date
    Nov 2007
    brooklyn, ny
    Posts
    6,933
    Ride
    2003 FX35 AWD
    Thanks Given
    12
    Thanks Received:
    103
    I have the same, 2 holes, the tpms sensor does not need to be used to fill the tire, I have the iforged ones on the front too...
    forgot to mention that the tpms should be 180% opposite the original tire valve for balancing purposes...
  5. #5
    Join Date
    Apr 2008
    Dallas, TX
    Posts
    17,822
    Ride
    2007 FX35 RWD
    Thanks Given
    50
    Thanks Received:
    202
    I used a bit about that big once. It was like $30!
  6. #6
    Join Date
    Nov 2007
    brooklyn, ny
    Posts
    6,933
    Ride
    2003 FX35 AWD
    Thanks Given
    12
    Thanks Received:
    103
    wow, I forgot I even put this thread up, always thought to but forgot that I actually did just seen it doing a search for tpms to find a place to post this:
    good thing I have the tpms, last night I left the shop really late & I jumped in the fx & shot towards the highway all of a sudden after a block or 2 my dash starts beeping a long beeeee-p, I look & it tells me I have a flat, check my tpms display & see it's the right rear, down to 25psi. I get out & look at it, it looks fine, I feel it, it feels fine, so I think hmm, maybe a sensor problem? break out a pressure gauge & sure enough, 25psi. I went back parked the fx & took my other car home. checked it today & yeah, she caught a thorn in her paw... a nice long screw right in the middle of the tread :frown: plugged her up & good to go. without the tpms I would have never known... I love the tpms
    also want to add if you don't have tpms, it doesn't mean you can't have it. I put an aftermarket set of tpms on my other car & they are really cool. in a way the aftermarket tpms is even better than the oe setup, because the aftermarket sends a reading as soon as you start the car, where the factory setup needs you to drive a little bit to reactivate the sensors before you can even get a warning. also the aftermarket has it's own display showing the location of each wheel & you can set low & high warning limits unlike the factory which can't be changed or adjusted at all. I put a set of hre's on the other car & they also needed to be redrilled, just like these iforged. a few shots:
    finding a good spot on the hre's was tough, there for a fwd car so the wheel is a bit different from what would be on an fx, I winded up having to put them in the middle of the rim
    the aftermarket ones I used are 2 piece & are adjustable for mounting angle which helps, where the oems are fixed & if the angle is no good not much you can do.
    I needed a little more angle so I had to drill new holes. I winded up siliconing them in after so they are very secure too
    here is the valve mounted before mounting the sensor
  7. #7
    Join Date
    Nov 2007
    brooklyn, ny
    Posts
    6,933
    Ride
    2003 FX35 AWD
    Thanks Given
    12
    Thanks Received:
    103
    sensor mounted
    wheels are dusty as hell in this shot but I redid them fresh black centers & resealed & reassembled the wheels & now they don't leak at all. here you can see where the new valve exits between the spokes.. easy enough to use where it is & enough clearance to the brakes & everything else on this car. I have to fill the tire from the new valve because HRE screwed up this set of wheels by drilling the original hole for the tire valve way too close to the 3 piece seal & they were plauged with constant leaks before I redid them. you can see where the original valve was opposite the new valve. I had to just seal off the original holes all togeather to make these rims even usable again
  8. #8
    Join Date
    Dec 2007
    Westchester, New York
    Posts
    7,066
    Ride
    2009 FX50
    Thanks Given
    3
    Thanks Received:
    102
    oh thanks man you drilled those just for me? haha
    .....great write-up!!
  9. #9
    Join Date
    Nov 2007
    brooklyn, ny
    Posts
    6,933
    Ride
    2003 FX35 AWD
    Thanks Given
    12
    Thanks Received:
    103
    haha, offsets a bit off for you bro, I can drill my maya's or assanti's just for you though :cool: :tonguey:
    also forgot to add that the aftermarket setup also gives temperatures too! a really nice thing to add to any car that don't have tpms. I won't ever have another car without it. oh yeah, one more thing... the aftermarket kit has the ability to add another 5th sensor for the spare too... & you can get 4 extra sensors for your winter wheels for like another 100 bucks & reprogram yourself whenever you swap wheels or rotate your tires even. I like the aftermarket setup so much that I kinda wish I used that in the fx instead of the factory sensors... if anyone is interested in thinking about the aftermarket tpms this is the kit I used & I got it from these people. I haven't been able to find it anywhere else
    http://www.vivaperformance.com/catal...roducts_id=444
    this is what the display control looks like. yeah it lights up green so maybe that would need to be modded to orange in an fx, I need to mod my other one to red eventually. it even shows battery life for each sensor, along with psi & temp & position on car. the display is tiny & can fit above the rear view mirror along the edge of the headliner
    and the kit, very easy to install, just 3 wire hook up, power/ign & ground
  10. #10
    Join Date
    Apr 2009
    Los Angeles
    Posts
    114
    Ride
    2005 FX35 RWD
    Thanks Given
    Thanks Received:
    I bought giovanna 2 piece wheel. there is the same, 2 holes.
    i don't know why there is 2 holes. but..I understand what it is..
    great write up.
  11. #11
    Join Date
    Jul 2007
    Illinois
    Posts
    6,156
    Ride
    2003 FX45
    Thanks Given
    96
    Thanks Received:
    129
    This is a great write-up. Decided to drill my wheels instead of using adapters. My mechanic drills TPMS on wheels all the time, but still nice for me to provide him with a printout of this and the exact tools you use for Infiniti 2003-2008 TPM sensors (TPMS).
    ---------- Post added at 09:11 AM ---------- Previous post was at 09:10 AM ----------
    BTW I was googling this to see pictures, and who would have thought our own resident Turbocad has a specific write-up for iForged and Infiniti FX03-08 that came up as a search result. That's called winning.
  12. #12
    Join Date
    Jul 2009
    Boston, MA
    Posts
    4,731
    Ride
    2012 FX35 AWD
    Thanks Given
    72
    Thanks Received:
    107
    Where can I find four aftermarket TPMS for $100 for my FX50 wheels since the ones that the rims came with won't work with the 1st generation FX
  13. #13
    Join Date
    Jul 2007
    Illinois
    Posts
    6,156
    Ride
    2003 FX45
    Thanks Given
    96
    Thanks Received:
    129
    http://revolutionsupply.com/AppGuide.aspx
    F
    ind the part number there, then google or ebay search for the cheapest price.
  14. #14
    Join Date
    Jun 2007
    Santa Clarita, CA
    Posts
    10,331
    Ride
    2005 FX45
    Thanks Given
    6
    Thanks Received:
    19
Similar Threads
  1. Infiniti FX FX35 FX45 Aftermarket In-Dash Aftermarket Navigation System
    By umoms in forum FX (03-08) - Electronics & Lighting
    Last Post: 01-26-2016, 12:26 PM
  2. Drill-less front liscence Plate Holder?
    By Fire0nic3 in forum FX (03-08) - Interior & Exterior
    Last Post: 10-23-2010, 01:04 PM
  3. Drill and slotted rotors
    By dulla in forum FX (03-08) - Wheels & Suspension
    Last Post: 11-14-2009, 07:52 AM
  4. TPMS - Aftermarket sensors for cheap!
    By Chedman13 in forum FX (03-08) - Wheels & Suspension
    Last Post: 09-09-2009, 12:41 PM
  5. Some questions about aftermarket rims.
    By blackzroadster in forum FX (03-08) - Wheels & Suspension
    Last Post: 04-29-2009, 12:30 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
