What's New Home Forum Top
Supporter Rides
Register
Welcome to InfinitiScene.com!
Page 1 of 2 12 LastLast
Results 1 to 20 of 32
  1. #1
    Join Date
    Feb 2008
    Inland Empire!
    Posts
    277
    Ride
    2004 FX35 AWD
    Thanks Given
    Thanks Received:
    MAINT Air bag light on dash flashing..help!
    I have a icon flashing on my dash with a man sitting in a seat with the air bag blowing up in his face flashing red. Can someone please tell me what may be the cause of this ? Also how can i get off of my dash from flashing ?
    Register
  2. #2
    Join Date
    Jun 2007
    Los Angeles, CA
    Posts
    12,697
    Ride
    2005 FX35 RWD
    Thanks Given
    125
    Thanks Received:
    145
    Salvage title? . . J/K, try an ECU reset
  3. #3
    Join Date
    Feb 2008
    Inland Empire!
    Posts
    277
    Ride
    2004 FX35 AWD
    Thanks Given
    Thanks Received:
    How can i do the ECU reset ?
  4. #4
    Join Date
    Jun 2007
    Los Angeles, CA
    Posts
    12,697
    Ride
    2005 FX35 RWD
    Thanks Given
    125
    Thanks Received:
    145
  5. #5
    Join Date
    Feb 2008
    Inland Empire!
    Posts
    277
    Ride
    2004 FX35 AWD
    Thanks Given
    Thanks Received:
    Thanks gto
  6. #6
    Join Date
    Nov 2007
    brooklyn, ny
    Posts
    6,933
    Ride
    2003 FX35 AWD
    Thanks Given
    12
    Thanks Received:
    103
    ecu got nothing to do with srs, flashing means trouble is present, do any work to the fx recently? gotta get it scanned to see what the fault is...
  7. #7
    Join Date
    Jul 2007
    Vancouver, BC
    Posts
    566
    Ride
    2005 FX35 AWD
    Thanks Given
    Thanks Received:
    11
    If you just want to reset the light you can do this procedure I found on the Org
    This is in reference to the little red airbag/seatbelt light -- the one that is in the middle of the gauges between the speedo and the RPMs.
    Thanks to Ak1nza and bradical for finding this information.
    HOW TO STOP THE AIRBAG LIGHT FROM BLINKING
    1. Turn ignition switch from OFF to ON.
    2. Within 1 second after air bag warning lamp is on for 7 seconds and turns off, turn off ignition switch.
    3. After ignition switch is turned off, wait for more than 3 seconds.
    4. Repeat steps 1-3 two more times (3 OFF to ON sequences in total)
    5. Turn ignition switch to ON.
    6. Turn ignition switch OFF and wait for more than 1 second then turn it back ON.
    The blinking airbag light should stop.
    If you just accidentally tripped the system you shouldn't have any more trouble. If there is a real problem with the airbag system the light will return.
  8. #8
    Join Date
    Jan 2009
    Montreal
    Posts
    349
    Ride
    2009 FX35 AWD
    Thanks Given
    Thanks Received:
    You can always bring it to the dealer, especially if it's stock. Airbag lights are all under warranty, and it doesn't take more than 15 minutes to do. Had that problem on my TSX, that solved it.
  9. #9
    Join Date
    Sep 2008
    prince rupert / prince george
    Posts
    102
    Ride
    2009 FX35 AWD
    Thanks Given
    Thanks Received:
    yeah ive only had my 09 for a few months, and the air bag light flashes, as well as the "passanger side airbag" light blinks as well, will this fix it?
    my closest dealer is 8 hours awayy lol
  10. #10
    Join Date
    Feb 2008
    Inland Empire!
    Posts
    277
    Ride
    2004 FX35 AWD
    Thanks Given
    Thanks Received:
    Quote Originally Posted by IlovemyFX View Post
    Here's the thread:
    http://www.infinitifx.org/viewtopic.php?f=62&t=2083
    i will give this a shot tommorow morning..
  11. #11
    Join Date
    Feb 2008
    Inland Empire!
    Posts
    277
    Ride
    2004 FX35 AWD
    Thanks Given
    Thanks Received:
    Just gave it a try, and i think that pretty much fixed the problem. i will test drive it later on to see if it came back on.. (prick fingers)
  12. #12
    Join Date
    Nov 2007
    brooklyn, ny
    Posts
    6,933
    Ride
    2003 FX35 AWD
    Thanks Given
    12
    Thanks Received:
    103
    yeah, yesterday I think I was dazed or something, cause I got it the other way around... flashing means there was a problem that set a code but it's NOT current... solid light is current...
  13. #13
    Join Date
    Jul 2007
    Vancouver, BC
    Posts
    566
    Ride
    2005 FX35 AWD
    Thanks Given
    Thanks Received:
    11
    Now that I think of it I think you were right the first time. Well, flashing or not, you should get the code read so you can diagnose what caused, or is causing, the warning light.
    By any chance did you recently change the in cabin air filter. If your not carefull with the harness that's in there you can cause an airbag warning light.
  14. #14
    Join Date
    Nov 2007
    brooklyn, ny
    Posts
    6,933
    Ride
    2003 FX35 AWD
    Thanks Given
    12
    Thanks Received:
    103
    yeah, now I'm not sure either way tbh. wonder if it was a steady flash or flashing a code, I know I have a fault in mine & the light is steady... I would think maybe it wasn't current if it turned off after the reset, otherwise it woulda popped right back on...
  15. #15
    Join Date
    Jun 2007
    South Gate, CA
    Posts
    4,845
    Ride
    2004 FX45
    Thanks Given
    18
    Thanks Received:
    13
    Just had this happen to me this morning...
    I just installed 2 12 inch Absolute Subwoofers and amp..
    the AirBag light is also flashig..
    I will try what was previously posted and see if it works.
  16. #16
    Psiclne Guest
    wow - two 12's for your best of Menudo cd?
    let us know what happens with the lights
  17. #17
    Join Date
    May 2008
    Los Alamitos
    Posts
    32
    Ride
    Other
    Thanks Given
    Thanks Received:
    This cheryl from metro the aor bags are not working need to get it to a dealer.
  18. #18
    Join Date
    Jun 2007
    South Gate, CA
    Posts
    4,845
    Ride
    2004 FX45
    Thanks Given
    18
    Thanks Received:
    13
    Quote Originally Posted by Psiclne View Post
    HA...
    No I am rocking the new Jackie Chan PoP CD from China... It rocks..
    ha ha
    I will post pics up when the rain stops...
  19. #19
    Join Date
    Aug 2008
    Hesperia, CA
    Posts
    2,742
    Ride
    2004 FX35 RWD
    Thanks Given
    21
    Thanks Received:
    92
    Quote Originally Posted by HumbertoCALI View Post
    HA...
    ha ha
    Please don't post pics....I don't want to see the hack jobs they do in South Gate !
    did you do the reset? airbag light off now?
  20. #20
    Join Date
    Jun 2007
    South Gate, CA
    Posts
    4,845
    Ride
    2004 FX45
    Thanks Given
    18
    Thanks Received:
    13
    Quote Originally Posted by toy4x View Post
    You should know... you worked on it with that gimp hand of yours... ha ha
    Have not had time to reset and work on it..I will try to get to it tonight...
    ---------- Post added at 11:19 AM ---------- Previous post was at 11:19 AM ----------
    "AND I'LL FORM THE HEAD"
    VOLTRON Kicks ASSS..
Similar Threads
  1. [FX35 03-08] Air BAG WARNING LIGHT FLASHING
    By sch4400 in forum FX (03-08) - Electronics & Lighting
    Last Post: 08-01-2011, 07:10 PM
  2. [FX35 09-12] My 2009 FX35 airbag light is flashing
    By Fire0nic3 in forum FX (09+) - Electronics & Lighting
    Last Post: 05-05-2011, 03:56 AM
  3. [FX35 03-08] Security Indicator Light Not Flashing
    By FXist in forum FX (03-08) - Electronics & Lighting
    Last Post: 07-26-2010, 05:16 AM
  4. [FX35 03-08] Dash light
    By k3fir in forum FX (03-08) - Electronics & Lighting
    Last Post: 04-23-2010, 11:06 PM
  5. [FX35 09-12] AFS light flashing
    Last Post: 04-16-2010, 04:34 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
