What's New Home Forum Top
Supporter Rides
Register
Welcome to InfinitiScene.com!
Page 1 of 8 123 ... LastLast
Results 1 to 20 of 152
  1. #1
    Join Date
    Jul 2007
    San Diego, CA
    Posts
    79
    Ride
    2003 FX35 AWD
    Thanks Given
    Thanks Received:
    5
    DIY HOW TO: Changing Transmission Fluid
    So I just took the plunge into my first tranny fluid change and took some pics. I used 5 quarts instead of flushing all of it.
    Check out the technical documents here:
    FX: Changing Transmission Fluid - InfinitiScene.com
    THINGS YOU'LL NEED:
    1. Nissan Matic J transmission fluid (got lucky and found some on ebay but most likely you'll have to go to a Nissan dealer and pay $15/qt)
    2. 10mm socket
    3. bucket
    4. plyers
    5. a friend to help
    6. funnel
    7. ramps/jack stands (so you can fit the bucket under)
    STEPS:
    1. Lift car and remove splash guard.
    2. Remove the engine cover so you can get to the charging pipe behind the engine.
    3. Unscrew the 10mm bolt holding the dip stick in. Remove the dip stick.
    4. If you're replacing X quarts of fluid, fill your bucket with X quarts of water and make a line at the water level. This way you'll know when do stop draining.
    5. Get all your Nissan Matic J transmission fluid opened and lined up so you or you're friend can continuosly pour. Start your engine (nothing will drain without the engine running).
    6. Get under the engine with your bucket ready. You'll be removing the smaller hose from the radiator (see picture).
    7. With your plyers, squeeze the hose clamp and slide it farther up the hose.
    8. Put your bucket directly below the end of the hose and get positioned so you can watch the fluid level reach the line on the inside of the bucket.
    9. Pull the hose off the radiator. I used plyers on this step but it might be easier to just use your hand. TIP: JUST AS THE HOSE RELEASES FROM THE RADIATOR, GIVE IT A PINCH TO STOP THE FLUID FROM SPRAYING ALL OVER YOUR GARAGE!. Otherwise you're garage will look like this.
    10. Yell to your friend to start pouring. Aim the hose at the bucket and stop pinching. Watch the fluid fill the bucket. As soon as it reaches the line in the bucket, pinch the hose again and reconnect it to the radiator. Hopefully all the old fluid is in your bucket and not on your body/garage floor.
    11. Slide the hose clamp back to the end of the hose with your plyers.
    12. Turn off your engine and give your friend a high five or a kick in the nuts, depending on his performance.
    13. Put the splash guard back on. Screw the dip stick bolt back into the charging pipe. Put your engine cover back on.
    14. Good work, now go drink a beer and order some more mods for your FX.
    See More: HOW TO: Changing Transmission Fluid
    Register
  2.    The Following 4 Users Say Thank You to shralp For This Useful Post:
  3. #2
    Join Date
    May 2007
    California
    Posts
    12,056
    Ride
    Other
    Thanks Given
    304
    Thanks Received:
    365
    Thanks for this, very good write-up.
  4. #3
    Join Date
    Nov 2007
    Austin, TX
    Posts
    67
    Ride
    2003 FX35 RWD
    Thanks Given
    Thanks Received:
    Thanks for the post. I tried to figure out how to check my tranny fluid yesterday and couldn't find the dipstick location. All the owner's manual had to offer was to suggest taking my car to the Infiniti dealer.
  5. #4
    Join Date
    Feb 2008
    South Bay 310
    Posts
    631
    Ride
    2003 FX35 RWD
    Thanks Given
    3
    Thanks Received:
    Trannsmission Drain Plug
    Is there a drain plug for our Fx35's?
  6. #5
    Join Date
    May 2007
    California
    Posts
    12,056
    Ride
    Other
    Thanks Given
    304
    Thanks Received:
    365
    Quote Originally Posted by puhahacj View Post
    It is not actually a plug but a hose from the lower part of the radiator. Look at step 6 above.
  7. #6
    Join Date
    Mar 2008
    Ontario/Inglewood, Cal
    Posts
    118
    Ride
    2005 FX35 RWD
    Thanks Given
    11
    Thanks Received:
    is this just a half flush?
    cuz u got to change the filter to right!
  8. #7
    Join Date
    Nov 2008
    NYC
    Posts
    3,025
    Ride
    2005 FX35 AWD
    Thanks Given
    2
    Thanks Received:
    8
    How much does it cost to get a T flush by the stealership? Does anyone know!
  9. #8
    Join Date
    Mar 2008
    Southern California
    Posts
    5,928
    Ride
    2005 FX35 RWD
    Thanks Given
    50
    Thanks Received:
    11
    Metro Infiniti told me that they never flush the tranny. they just do a fluid change. (cycle trans fluid until it clean)
    the reason stated was it can damage the trans.
  10. #9
    Join Date
    Mar 2008
    Southern California
    Posts
    5,928
    Ride
    2005 FX35 RWD
    Thanks Given
    50
    Thanks Received:
    11
    BTW great write up Shralp.
    Would disconnecting the line (and aiming into bucket) before you start the engine prevent the spillage?
  11. #10
    Join Date
    Nov 2008
    NYC
    Posts
    3,025
    Ride
    2005 FX35 AWD
    Thanks Given
    2
    Thanks Received:
    8
    Cool, thanks for the info
  12. #11
    Join Date
    Jan 2009
    DFW, TX
    Posts
    22
    Ride
    2007 FX35 RWD
    Thanks Given
    Thanks Received:
    Quote Originally Posted by theMerchant View Post
    Thats what im wondering, or at least wouldnt be as messy?
    Great writeup though BTW!
  13. #12
    Join Date
    Jan 2009
    miami
    Posts
    851
    Ride
    2004 FX35 RWD
    Thanks Given
    Thanks Received:
    thanks . very helpful . il be doing a transmission fluid change this weekend
  14. #13
    Join Date
    Apr 2009
    Dallas, Tx
    Posts
    538
    Ride
    2003 FX45
    Thanks Given
    35
    Thanks Received:
    7
    I did this last weekend. dealership wanted $120, fluid included. Service guy said they usually "drain and fill" 6qts. make sure to pinch the hose when taking off, and pinch when putting the hose back on, and you should minimize mess.
  15. #14
    Join Date
    Jun 2009
    richardson,TX
    Posts
    455
    Ride
    2005 FX35 AWD
    Thanks Given
    18
    Thanks Received:
    10
    good tips,thanks. :cool::biggrin::rolleyes:
  16. #15
    Join Date
    Aug 2009
    USA
    Posts
    31
    Ride
    2005 FX35 AWD
    Thanks Given
    Thanks Received:
    Is there a filter for the transmission fluid?
  17. #16
    Join Date
    Dec 2009
    NY
    Posts
    91
    Ride
    2010 FX35 AWD
    Thanks Given
    Thanks Received:
    :tup: thanks!!
  18. #17
    Join Date
    Jan 2010
    San Diego
    Posts
    75
    Ride
    2003 FX35 RWD
    Thanks Given
    Thanks Received:
    talked to the dealership yesterday. they said a flush and fill was not a good thing to do. he recommended having it flushed. he said that if you flush and fill, you are only getting half the fluid out, and you are contaiminating the new fluid right away with all the old stuff left in there. he said they do it for 350. that is including the 10 quarts which is very expensive. i might go that route.
    ---------- Post added at 12:42 PM ---------- Previous post was at 12:42 PM ----------
    i meant the "drain and fill" was not a good thing to do. he recommended the flush
  19. #18
    Join Date
    Apr 2009
    Ontario
    Posts
    2,591
    Jeff
    Ride
    2004 FX35 AWD
    Thanks Given
    246
    Thanks Received:
    115
    Quote Originally Posted by noodlelegs View Post
    No, there is no filter inside
  20. #19
    Join Date
    Aug 2009
    USA
    Posts
    31
    Ride
    2005 FX35 AWD
    Thanks Given
    Thanks Received:
    I was also told that the drain and fill was not good. Because there could still be contaminated fluid in the system. But I am not an Infiniti mechanic, so I guess I will just to the drain and fill.
  21. #20
    Join Date
    Feb 2010
    Austintatious, TX
    Posts
    2,938
    Sj
    Ride
    Other
    Thanks Given
    4
    Thanks Received:
    11
    but you will have to run the engine in idle to drain the liquid. Emptying the trans fluid while engine running can damage the transmission.
  22.    The Following User Says Thank You to bleedingsujit For This Useful Post:
Similar Threads
  1. [FX35 03-08] Changing power steering fluid
    By fx35_UCH in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 01-24-2014, 07:05 AM
  2. [FX35 09-12] I think my dealer used the wrong fluid in my transmission
    By Fire0nic3 in forum FX Community
    Last Post: 01-20-2011, 08:27 PM
  3. [FX35 03-08] transmission fluid help
    By FXchris305 in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 06-01-2010, 04:38 PM
  4. [FX35 03-08] Transmission Fluid selection?
    By FX35AWD in forum FX (03-08) - FX35 Engine & Drivetrain
    Last Post: 09-29-2009, 06:35 AM
  5. [FX35 03-08] transmission fluid level . help !
    Last Post: 04-10-2009, 11:42 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
