What's New Home Forum Top
Supporter Rides
Register
Welcome to InfinitiScene.com!
Results 1 to 18 of 18
  1. #1
    Join Date
    Nov 2008
    Boston
    Posts
    119
    Ride
    2003 FX35 AWD
    Thanks Given
    Thanks Received:
    Sale Disc ITALIA Rotors and HyperCeramic Pads
    Want to share your experience with these?
    This is my setup (purchased and installed December last year):
    1. Disc Italia drilled and slotted rotors (I painted the exposed outer part of rotors in black hi-temp paint)
    2. Disc Italia HyperCeramic Pads - it was a great fit. Headache-free install.
    Impressions:
    • definitely VERY clean and solid setup. No brake dust at all. Only visible if you run your finger on the rim clearcoat after a wash and a few days of driving.
    • no rotor fade so far
    • pads aren't as grabby as OEM pads. I have to break earlier to stop in time. Is this attributed to pads being 100% ceramic? Stopping distance sightly improves as rotors heat up
    • whirring sound. Slotted rotors? I read it's normal to make this sound for slotted modules
    See More: Disc ITALIA Rotors and HyperCeramic Pads
    Register
  2. #2
    Join Date
    Jul 2007
    Joizy
    Posts
    1,219
    Ride
    Other
    Thanks Given
    Thanks Received:
    Got any pics of your setup?
    Quote Originally Posted by durak2000 View Post
    Is this true anyone? Since I installed my rotors, I've been hearing a sound coming from the outside of the FX but I cant seem to figure out what it is.
  3. #3
    Join Date
    Jun 2007
    California
    Posts
    12,034
    Ride
    Other
    Thanks Given
    301
    Thanks Received:
    358
    Dimpled rotors will make an airy sound as the dimples pass the pads, I have first hand experience with this. Drilled rotors will make less noise or maybe even none (which is what I have now). Not sure on slotted.
    You really can hear the noise while passing a wall or guardrail.
  4. #4
    Join Date
    Jul 2007
    Joizy
    Posts
    1,219
    Ride
    Other
    Thanks Given
    Thanks Received:
    Quote Originally Posted by fxlr8 View Post
    I guess that explains the sound, I have slotted and dimpled.
  5. #5
    Join Date
    Nov 2007
    brooklyn, ny
    Posts
    6,933
    Ride
    2003 FX35 AWD
    Thanks Given
    12
    Thanks Received:
    103
    I know that I could hear my rotoras stopping, not really in a bad way but kinda almost like a turbine whine, you could realy hear them stopping & they stopped awesome, but I did get them used & the pads were maybe half worn, not sure if they make this noise when new...
  6. #6
    Join Date
    Nov 2008
    Boston
    Posts
    119
    Ride
    2003 FX35 AWD
    Thanks Given
    Thanks Received:
    they only make the noise when the brake pedal is depressed. They are dead quiet while driving.
  7. #7
    Join Date
    Nov 2008
    Boston
    Posts
    119
    Ride
    2003 FX35 AWD
    Thanks Given
    Thanks Received:
    Quote Originally Posted by jc'sfx View Post
    I'll get the picture as soon as I can.
  8. #8
    Join Date
    Nov 2008
    Boston
    Posts
    119
    Ride
    2003 FX35 AWD
    Thanks Given
    Thanks Received:
    I rotated tires about a month ago. Took the wheels off and checked the pads while I was there - the Disc Italias pads look fantastic and generally hold up suprisingly well. There is normal rust on the back of the rotor.
    I did refresh the brake grease coating between the shims.
  9. #9
    Psiclne Guest
    FYI-
    You guys can use the button to multi quote....instead of 3 or 4 posts in a row unless youre a newbie trying to reach the minimum post count to post pics
  10. #10
    Join Date
    Nov 2008
    Boston
    Posts
    119
    Ride
    2003 FX35 AWD
    Thanks Given
    Thanks Received:
    Quote Originally Posted by Psiclne View Post
    FYI-
    That's it! :.smile:
  11. #11
    Join Date
    Nov 2008
    united states
    Posts
    Thanks Given
    Thanks Received:
    Have they gotten grabbier since the install? Anymore impressions?
  12. #12
    Join Date
    Nov 2008
    Boston
    Posts
    119
    Ride
    2003 FX35 AWD
    Thanks Given
    Thanks Received:
    Quote Originally Posted by iloveit View Post
    No they have not. The performance is always rock solid and predictable though: stopping power increases as rotors and pads heat up. No rotor fade so far. It's a bit different from what we are used to with OEM setup...
  13. #13
    Join Date
    Nov 2008
    Boston
    Posts
    119
    Ride
    2003 FX35 AWD
    Thanks Given
    Thanks Received:
    Updated: PIX
    Front
    ...and rears
  14. #14
    Psiclne Guest
    So these arent BBK? Just Drilled...right?
  15. #15
    Join Date
    Mar 2008
    Southern California
    Posts
    5,928
    Ride
    2005 FX35 RWD
    Thanks Given
    50
    Thanks Received:
    11
    Impressions:
    I think ceramic pads can be dangerous if you need to suddenly stop. and the rusty rotors, some have a better coating (zinc).
    thanks for sharing:tup:
  16. #16
    Join Date
    Nov 2008
    Boston
    Posts
    119
    Ride
    2003 FX35 AWD
    Thanks Given
    Thanks Received:
    These are DISCItalia cross-drilled and slotted :biggrin:
  17. #17
    Join Date
    Nov 2008
    Boston
    Posts
    119
    Ride
    2003 FX35 AWD
    Thanks Given
    Thanks Received:
    Quote Originally Posted by themerchant View Post
    I do have to stop a bit earlier with these pads, but it's no problem especially after the system heats up enough. There is less bite than with metallic compound pads but the braking power is uniform and constant.
    My 07 G35, for instance has ridiculously grabby brakes - I have 24K on the car and I already need to resurface the rotors.
    The rust is just a thing layer on the inside of the rotors - these are only a year old. I do live in a snow belt area with tons of salt and sand in the winter months, so things rust quickly. I have used aftermarket Brembos on other cars before and they rust much quicker than these.
  18. #18
    Join Date
    Nov 2008
    San Diego
    Posts
    61
    Ride
    2003 FX45
    Thanks Given
    Thanks Received:
    I had Disc Italia rotors on my Stealth a few years ago. They performed great, but since the Stealth is a show car, I couldn't accept the rusting. I got some R-1 racing zinc coated rotors on there now and they look like brand new after 2 years and perform just as well. (I also autocross the car once and a while)
Similar Threads
  1. [FX35 03-08] Buying new rotors and pads soon...
    By Mylo in forum FX (03-08) - Wheels & Suspension
    Last Post: 11-16-2012, 04:31 PM
  2. [FX45 03-08] rotors and pads?
    By 978fx45 in forum FX (03-08) - Wheels & Suspension
    Last Post: 04-20-2011, 01:40 PM
  3. [FX GEN1] DIY Rotors & Pads
    By onyx fx in forum FX (03-08) - Wheels & Suspension
    Last Post: 03-25-2011, 11:10 AM
  4. [REVIEW] Best rotors and pads
    By Greeksneak in forum Deals & Reviews
    Last Post: 10-26-2010, 09:06 AM
  5. [FX35 03-08] New Pads and Rotors
    By Tko512iFX in forum FX (03-08) - Wheels & Suspension
    Last Post: 12-11-2009, 08:58 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
